Not Startingup right away, carb problem?
Old May 31, 2011 | 07:51 PM
AKcamaroAK's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 350 V8 4bbl
Transmission: Automatic 700r4
Axle/Gears: 2.73 Open Diff
So my 86 z28 has a brand new engine in it (carb'd of course) and when I turn the key, it turns over for a few seconds and I have to give it some gas to start it up. My dad says it's just because it's a carb'd motor, but I think it takes to long to start up.
Last night I tried tuning my carb, which I'm inexpeiranced in doing, and I thought I had fixed it. But this morning it was doing the same thing again (taking to long to start). On the bright side,my idle sounds better than before.But I still want to turn the key and have it start right up. Any ideas?
-Daniel
Old May 31, 2011 | 09:53 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Not Startingup right away, carb problem?
my 86 does this too and its FI so i wanna know aswell. its imbarressing when it does this in the parking lot
Old May 31, 2011 | 10:08 PM
AKcamaroAK's Avatar
Engine: 350 V8 4bbl
Exactly! The other day I was leaving Taco Bell, and I dont live in the best area so all these gang bangers where hanging out around there. I was trying to start it up, and they just laughed at me... anyone else would get a earful of choice words lol, but I wont risk it with someone who might have a gun.
Old May 31, 2011 | 11:51 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
i see your in alaska... this could have some to do with your choke. it might need to be adjusted as its not always the warmest there. also the floats in your carb could be draining which i know could cause this. i am no carb pro by any means this is just my
Old Jun 1, 2011 | 10:59 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Describe your starting procedure from when you sit in the car until it starts.
Old Jun 1, 2011 | 11:02 AM
Engine: L31 350
if hes like me, i get in, turn the key so the pump can prime and pump up alittle gas, then try and start.
Old Jun 1, 2011 | 11:11 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, which is wrong for a carbureted car, so I want to know what he's doing.
Old Jun 1, 2011 | 07:41 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
That's what I do also. So what is correct way.
Old Jun 1, 2011 | 08:32 PM
AKcamaroAK's Avatar
Engine: 350 V8 4bbl
I do exactly what evilemokid94 said haha. Today I tried adjusting the the electric choke on my carb. Seemed to help, but at that time the engine was still warm. The real test will be tomorrow morning when I go to work.
Old Jun 2, 2011 | 08:36 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Set the choke tension so that the choke plate is just barely held closed with the engine cold. From there you can make small adjustments either way as necessary.
To start the car, put the pedal to the floor and let it all the way off once to set the choke and give it an initial pump shot. In very cold weather you may need to do it twice. Then turn the key and start the car. If it doesn't catch within a few seconds, gradually ease the pedal to the floor while continuing to crank. Don't run the starter more than 10-15 seconds.
In -20 C weather (that's about -5 F for those in the benighted states of America), my 84 will start before the starter has turned the engine through a full rotation.
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
overdriv
Aug 20, 2015 03:52 PM
