Carter M6626 Fuel Pump
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Does the OE metal line to the carb fit the M6626?
JamesC
JamesC
Re: Carter M6626 Fuel Pump
Excellent. Many thanks.
JamesC
JamesC
Well, based on the idea that the OE line would fit the Carter, as it's a direct replacement, I purchased the Summit version of the following kit (all parts are the same size with the exception of hose length):
http://www.jegs.com/InstallationInst...555-100810.pdf
The long and short of the situation is that neither of the fuel pump fittings are correct for my pump. Apparent, the OE fitting is Male 5/8 in.-18 Inverted Flare.
The part is coming soon, so we'll see.
JamesC
JamesC
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
This is what you would have wanted to fit a stock pump, but it still wouldn't have fit at the carb end http://www.summitracing.com/parts/AER-FCP0139/
Double post.
JamesC
JamesC
The Summit kit I purchased fits the Holley 4160 I'm running, so with the correct pump fitting, I "should" be good to go.
From Napa for my OE pump: Fuel Pump Fitting Size[s] : Inlet - 3/8", Outlet - 5/8" - 18 UNF - 2B
Obviously my research fell short.
JamesC
JamesC
James
An old and ancient thread I know (and I'm not referring to the poster or postee...) however what was the outcome of your experience? Is the Summit version different from Carter? The M6626 as I've found it listed has a 3/8" inlet for a rubber hose end and gear clamp, the same for the return but at 1/4" and a 3/8" NPT female inlet fitting.
Sounds about right? I've researching something like this and came across it on a thread I've started.
https://www.thirdgen.org/forums/carb...-pump-who.html
Any info is appreciated.
Thanks.
Thanks.
I thought it said 3/8" NPT but I guess I'm confusing that with another pump. My Edelbrock has 3/8" NPT in and out with no return. It's the return I'm after.
I'll be looking for an adaptor from 3/8 inverted flare to -6 AN I guess to go with my carb feed line.
Something to replace this 3/8 npt to -6 an.
Thanks.
Thanks.
I ended up using an Edelmann 251660, pump to carb (and bending it 90 degrees) from O'Reilly's:
Transmission Oil Line Coolant Adapter - 3/8 Inch Tube Size x 3/8 Inch (5/8-18) Male Inverted Flare x 4 1/2 Inch Length
JamesC
JamesC
Well, one end of that would work for me. The 3/8" inverted flare fitting is half of what I'm after. Now I just to find an adaptor that fits on -6 AN female hose end.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
