What to do with hvac vacuum when going carb
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I put a new engine in my 90 iroc this past spring, went carb with it. Now what do I do with the vacuum lines that feed the vent-ac controller? I found the 2 on the outside that were fed by the other engine, but I did away with all the smog and tpi stuff. What can I hook these to, or what am I missing?
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: What to do with hvac vacuum when going carb
HVAC hooks to full-time manifold vacuum. The port for the brake booster is an acceptable location for a T-fitting.
Car: A lousy LS1 car
Engine: 347 Cu. In.
Transmission: Which One?
.....or there could be a port in the manifold that is plugged. Remove the the plug and install the appropriate fitting. I've seen some that looked like a small freeze plug but were in fact in the vacuum stream.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
as stated, the inlet gets full manifold vacuum. the other hose goes to the heater diverter valve. if you got rid of that too then you just cap the other line off.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks for the replies, so if I got rid of the diverter valve, which I did. the line I need to cap is the one with a straight hose fitting? The other line I see has a 90' hose fitting on it.
Car: 91 Camaro RS
im pretty sure the one with the straight fitting is for the diverter.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks guys I got it fixed with your help. Also thanks to the mods for letting this topic ride here. But I figured it was a question that most carb guys could answer, even though it was a hvac question it was carb related.
