tv linkage too long
Old Jun 3, 2012 | 09:34 PM
neverfinished88's Avatar
Car: 88 Camaro
Engine: 5.0
Transmission: 700r4w/shift kit
Axle/Gears: 10 bolt
tv linkage too long
i did carb the tbi to carb swap on my 88 camaro i got a 600 holley vac sec so i bought the tv cable geometry from holley and the piece tha goes onto the carb but when i put the tv cable on the bracket the tv cable is to long there is to much slack in the line i have adjusted the cable all the way back need help bad
Old Jun 3, 2012 | 11:33 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: tv linkage too long
I've never had luck with aftermarket brackets. I suggest going with Bowtie Overdrives TV bracket. By far the best bracket I've ever used. I replaced my Edelbrock setup (it's not in the trash, I refused to sell it to anyone).
Old Jun 4, 2012 | 03:09 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I temporarily spaced mine out with some tie-wraps, to take up the slack. Got a new adjustable bracket to fix it permanently, but the dodgy fix worked so well I still haven't gotten round to replacing it after nearly a year.
Old Jun 4, 2012 | 08:49 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your stud location is wrong.
Old Jun 4, 2012 | 09:42 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Heh probably! As far as I've ever been able to tell from pics online and waving parts around at speed shops, I've got some oddball throttle arm on my Holley 4165, and some oddball throttle/tv bracket.
However, some online researching said the proper position is about 60% travel to the rear of the throttle shaft, and 1 1/8" from throttle shaft cl to stud cl. One of the holes in the throttle arm is exactly there, so I used it. Incorrect?
The shifts are near perfect, and better than the years I spent with the stud located further forward (still required a little spacing).
The tie-wraps are goofy of course, but might get the OP out of a jam. In my case, either the bracket should position the TV cable mount further back than it does, or my replacement generic cable has an inner cable that's too long. The new adjustable bracket will put it in the right spot.
Old Jun 4, 2012 | 11:05 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I used split shot to do mine the same way.
Im guessing the problem is caused by the difference in the TBI and TPI cables? Is this correct? I have no idea if one is longer or the other, but that is the only reason I could think. The old cable I had worked without issue on the same setup.
Old Jun 4, 2012 | 11:55 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Could be. Mine was a TPI to Holley swap, and the OP is TBI to Holley. I bought a TPI replacement cable because it was the cheapest locally at the time.
If length variations in fact are the difference between the various stock intake systems, stands to reason there would not be a stock replacement for Holley's that was the correct length, leading to these problems.
Old Jun 4, 2012 | 01:58 PM
Car: 88 Camaro
Engine: 5.0
Axle/Gears: 10 bolt
I have hears of people on here of using the spectra bracket and working fine so I think I might try that out and see how that works
corey8084
Sep 17, 2015 02:56 PM
Magman
Sep 14, 2015 01:30 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
