Edelbrock manifold
Old Feb 3, 2013 | 11:17 PM
Adrian harrison's Avatar
Car: 1983 Z28
Engine: 400 small block :)
Transmission: 350
Edelbrock manifold
just wondering what Edelbrock inlet manifolds will fit under the standard hood?
Old Feb 4, 2013 | 11:36 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Re: Edelbrock manifold
Performer and Performer RPM should fit without any problems.
Performer RPM Air-Gap can fit but with some issues as well. I have seen where a few people have experienced some issues and some didn't have any issues with these. I have a RPM Air-Gap on my 86 T/A. The original air cleaner would touch after I had aligned my hood so I installed an open element, drop base, air cleaner on it. I don't drive my car very much so I'm not worried about the filter element getting really dirty and about sucking in hot air from the engine bay.
Old Feb 4, 2013 | 11:40 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Yup I got the edelbrock 2101 performer intake and it fit perfectly when I had my stock hood.
Old Feb 4, 2013 | 03:19 PM
Stauf's Avatar
Car: 91 Z28 Coupe
have edelbrock 2101 with edelbrock 650 carb. With the air filter, it rests right against the hood. just make sore you have a drop down air filter cover, and I had to go with a 2.5" filter to make it fit
Posted from Thirdgen.org App for Android
Old Feb 4, 2013 | 05:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The RPM and RPM Air Gap are exactly the same height to the carb mount.
Old Feb 4, 2013 | 11:32 PM
Car: 1983 Z28
Transmission: 350
Thank you for this information as I have been trying to find this out and thanks for all the replys... I also have the TPI Intake Air Cleaner system I will be using, just have to get a carb hat o use with it
Old Feb 5, 2013 | 02:19 AM
jez3941's Avatar
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
I have a Performer RPM on my 84 T/A and it is a perfect fit for the stock air cleaner to match up to the hood intake.
Old Feb 5, 2013 | 08:11 AM
bestracing's Avatar
Engine: Broke - 350
I knew the RPM was a little higher than the base performer but didn't know it was the same height as the air-gap. Good to know. I've only had the base performer and the air-gap and have only dealt with those two as well.
Old Feb 5, 2013 | 01:50 PM
five7kid's Avatar
Edelbrock lists the dimensions on their website.
Pac J
May 17, 2020 10:44 AM
sreZ28
Oct 22, 2015 08:21 AM
Night rider327
Sep 25, 2015 04:47 AM
Rally Smith
Sep 14, 2015 06:59 PM
