replace egr intake with non egr
Old Jan 31, 2014 | 04:16 AM
mballejos87's Avatar
Car: 1984 camaro
Engine: 305 v8
Transmission: auto 4 speed
ok so a little history i have an 84 5.0 when i forst bought it i had to but an edelbrock carb to get it running and when i put it on i noticed it kinda took up alot of room so i had to loosen the egr for it to fit and i was thinking what if i replaced the intake manifold with one that doesnt have the egr would it make it worse or better or not even affect it at all
Old Jan 31, 2014 | 10:52 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: replace egr intake with non egr
The first question to ask is, does where you are require emisisons inspections?
Second question. W hat kind of edelbrock carb did you buy? Did you replace the distributor with a non-computer controlled distributor at the same time?
The car will run fine without the EGR, but the computer will throw a code. Also, the car will not pass emissions with the EGR disconnected. It'll also fail the visual portion of the emissions check if there is one and it's not there.
Old Jan 31, 2014 | 12:50 PM
Car: 1984 camaro
Engine: 305 v8
no i dont have emmisions,the carb is a 1405 non egr 600 cmf manuel choke and my distributor is non comp controlled
Old Jan 31, 2014 | 04:53 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Then go ahead and remove it, it won't affect anythng. The only issue will be that your computer may throw a code. However, if you leave the electrical connector connected even if the EGR is disconnected, I'm 90% sure that will keep the code from showing up.
Old Jan 31, 2014 | 06:21 PM
Car: 1984 camaro
Engine: 305 v8
ok thank you for the help
Old Feb 3, 2014 | 11:01 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
You don't necessarily have to replace the intake if you want to get rid of the EGR. There are block off plates available for that purpose, or you can even make your own.
Old Feb 3, 2014 | 11:07 PM
Car: 1984 camaro
Engine: 305 v8
really didnt know that
Old Feb 5, 2014 | 02:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
With an Edelbrock carb and vacuum/mechanical advance distributor, it should be throwing codes right now. Hooking up the EGR electrical connector won't change that.
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
drathaar907
Aug 6, 2015 04:20 PM
