Need help with intake and carb!
Old Feb 17, 2014 | 02:33 AM
1984Z28ttop's Avatar
Car: 1984 Z28 L69
Okay, so I am pretty sure this has been covered a million times before but I really had no idea how big of a mistake I had made. I recently picked up my z28 with a 350 swap with 305 heads on it. The heads are toast, and I managed to pick up a torn down 350 with with 2 perfect heads for $100. Main reason I picked up the 350 is for the heads was because I read so many horror stories about the 305/350 setup. The engine I bought is an 89 TBI engine out of an 89 blazer, and I did not know that they changed the heads in 87. (I have always worked with earlier 350s) I want to keep the carb setup already on the car, and am aware I will need the manifold. What I need to know is if I will need a new carb, and what intake manifold and gasket kit is best to use? I am working on a tight budget to get the car back on the road. Any help is appreciated and again sorry if all of this has already been asked and answered, I just want to make sure I am doing everything right.
Old Feb 17, 2014 | 02:57 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Need help with intake and carb!
if your talking about the 4 center intake manifold bolts being on a slightly different angle,...i've taken a drill and wallowed out the holes to the correct angle. it will seal up fine on the engine.
if you want to get creative, find some 3/8" pipe or tubing, cut it on the appropriate angles to fit between the bottom of the bolt and the top of the intake. i've made them about 1/4" long. doesnt take long. might need 4 slightly longer bolts though?
Old Feb 17, 2014 | 03:00 AM
Car: 1984 Z28 L69
That sounds like what I might wind up having to do. I really can not afford to buy the new manifold and new carb, but if I can just do that I will. Do I just use the standard gasket kit then?
Old Feb 17, 2014 | 03:04 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i'd use the gasket set for the heads.
it wont take but a minute to make sure every thing lines up while you have it apart.
Old Feb 17, 2014 | 03:12 AM
Car: 1984 Z28 L69
Okay thank you! I will let you know how it goes. Any advice on what I should do to prevent cracking or warping the Intake manifold? Like I said I want to make sure I am doing everything right.
Old Feb 17, 2014 | 03:23 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
follow your normal torque sequence. i usually start in the middle and work my way out.
try not to over-tighten it the first time. snug it up, then go back over it for final torque.
i throw those rubber gaskets away for the china walls. just lay a thick bead of rtv silicone.
i use washers under the intake bolts, and on top of the 4 spacers. heres a crude drawing of the spacers i was talking about. sorry, i suk at drawing, lol.
Old Feb 17, 2014 | 03:27 AM
Car: 1984 Z28 L69
lol, I suck at drawing as well. Thank you for the advice. I can not wait to get my car back on the road where it belongs.
Old Feb 17, 2014 | 03:34 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i wish ya luck. you should be fine. heres a link with some more info if your bored. i'm sure theres lots of info out there about the subject. let us know how you make out.
http://www.hotrod.com/techarticles/h...k/viewall.html
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
DJanes97
Sep 1, 2015 02:55 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
