Removing All Emissions Items, carb change needed?
Old Nov 17, 2014 | 11:39 AM
RQ Jay's Avatar
Car: 1985 TransAm
Engine: 4bbl 305
Transmission: Automatic
I am interested in removing all emissions Items (converters, EGR, AIR system, etc..) from my 1985.
Would I have to remove the electronic Quadrajet and replace it with a non electronic version to get the vehicle to run correctly?
Sorry for if this is an ignorant question, I am not nearly familiar with engines or carbs.
Thank you in advance for any help/direction given.
Old Nov 17, 2014 | 12:31 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: Removing All Emissions Items, carb change needed?
the computer controls the ignition and trans as well as the carb. so kind of depends what your goal is. if you only put a non cc carb on it it will run fine on the oem stuff. but if you want to get rid of the rest of the sensors, air systems, cats, and such, it seems easier to me to bypass the pcm all together. you can get non emissions sbc headers, one wire vacuum advance hei from aftermarket or 70s chevy. need to research one of the many ways to control lockup on a 700r4. you can get non emissions sbc manifold or block all the ports. if the car is already carbed i think thats it. you would have to get a non cc quad or aftermarket carb
Old Nov 17, 2014 | 01:57 PM
mlbinseattle's Avatar
Car: '84 Camaro Z28
Engine: 305 HO
The CCC Quadrajet needs the O2 and CTS connected to the ECM and functioning for the ECM to provide feedback to the carb. If you intend on removing the ECM, I would go with a different carb.
Old Nov 17, 2014 | 05:24 PM
RQ Jay's Avatar
Car: 1985 TransAm
Engine: 4bbl 305
Thank you for some answers... I had no idea the trans was controlled by the PCM as well... will have to learn more on that correction.
My intention is simply a weekend cruiser to take out on Saturdays.
It will be registered as a classic here in AZ, and I expect to put some low miles on it.
Just looking for a simple and clean engine area for a little bit of showoff.
Old Nov 18, 2014 | 06:48 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
aftermarket non emissions intake, carb, hei, and headers is what i would go with then. and you can get rid of everything on the harness that goes into the pass side. the gauges might be an issue though, i went with aftermarket the fuel and voltage were the only ones that worked on my 87. you may be able to fix it but i wanted the accuracy. obviously have to do the trans too.
Old Nov 18, 2014 | 11:32 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
You can make all factory gauges work if you delete the ECM, just need to know which wires to connect to. Your speedo is cable driven, tach will run off the distributor, fuel from the pump, coolant temp from the CTS, and volts from the alternator.
Old Nov 18, 2014 | 02:35 PM
RQ Jay's Avatar
Car: 1985 TransAm
Engine: 4bbl 305
You guys rock! Thanks for the info!
Old Nov 18, 2014 | 03:42 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
There's absolutely no reason to remove the ECM (not PCM-does not control the trans). It will continue to work fine even with the AIR and EGR deleted. Some earlier models will throw a code when the EGR solenoid is removed, but that can be bypassed.
My 87 runs fine with no AIR or EGR, headers and a six speed.
Saves a whole bunch of $$ in new intake, carb, distributor and converter lock up.
Old Nov 19, 2014 | 10:01 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
the early ones still had converter control. the speedo being mechanical is one less thing to worry about. there are wiring diagrams on austinthirdgen.
he is doing the stuff for looks, not just what you need to make it run right. to me even if you plug all the holes the original smog intake and the quad looks bad, too busy. aftermarket HEI, intake, headers, holley dp, looks alot better. only be a couple wires with that setup, and a couple tubes.
Old Nov 19, 2014 | 10:33 AM
naf's Avatar
naf
I think the qjet looks perfectly fine.
All used the ECM to control converter lockup.
Electric or mechanical speedo makes no difference. Either will work perfectly fine without the ECM.
PCM Powertrain Control Module
ECM Engine Control Module
Old Nov 19, 2014 | 01:37 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
so he has to figure which way he wants to go because he is going to use the 700 without the ecm.
when you take the whole harness out and start from scratch only adding what is necessary as i did it makes a difference. my 87 was electronic and it didnt work. the OPs is mechanical so dont have to worry about anything but the lockup.
Old Nov 25, 2014 | 04:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
None of those affect the computer carb. Leave it, the computer controlled distributor, and ECM alone. It's a better carb than any possible replacement. Bar none.
I would argue that there's not much point in removing the EGR. It doesn't affect performance, and removing it can lead to part-throttle pinging, which you'll have to combat by using higher octane gasoline, or backing off the timing. Doing either of those will cost you more money in gas, and doing the latter will cost performance. Why do it?
Old Nov 26, 2014 | 07:29 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
i did it for two reasons, one all that crap looks bad and busy, and two the old stuff never works as engineered almost 30 years ago, and i dont want to be chasing performance issues on old crap with a million things it could be. been there, not fun. if you have a aftermarket manifold and headers and aftermarket ign you dont have all that nonsense to cause you trouble and it runs good because there is nothing to break. and if you tune it properly it doesnt ping and gets just as good mileage as it would with the qjet. if you dont you didnt tune it right.
Old Nov 26, 2014 | 04:47 PM
five7kid's Avatar
Perhaps I missed it, but I don't see any reference by the OP to an aftermarket intake manifold.
Old Nov 27, 2014 | 06:11 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
he said he was looking for a clean engine area for a bit of show off. thats what that means to me, but its obviously just an opinion, depends what you think "clean engine area" looks like
Old Nov 27, 2014 | 08:41 AM
naf's Avatar
naf
someone's being snarky...
HTG TGO
Old Nov 27, 2014 | 09:59 AM
RQ Jay's Avatar
Car: 1985 TransAm
Engine: 4bbl 305
As mentioned I am looking to get the engine compartment cleaned up.
I have a 1996 5.7 from a 3500 truck that I will be looking at placing in my 85.
I have not checked officially, but the engine has a mechanism cal pump boss and block off plate.....just need to have a look and see if it has a fuel pump rod hole drilled.
I would like to keep the engine "old school"
Old Nov 27, 2014 | 10:23 AM
naf's Avatar
naf
the L31 should not have the fuel pump rod bored. but it is quick work for a shop.
assuming (?) L31 it should have the vortec heads but the stock springs are weak and limit lift. the LS6 spring swap is an economical alternative.
the entire ECM harness can be carefully removed through the fenderwell. the only ECM connection that needs to be replaced is the lockup connection to the trans.
Old Nov 27, 2014 | 11:45 AM
RQ Jay's Avatar
Car: 1985 TransAm
Engine: 4bbl 305
Thanks for the advice!
Regarding the spring concerns, is that something to worry about if I leave the block stock? I had only planned on an intake manifold change.
Old Nov 27, 2014 | 02:32 PM
naf's Avatar
naf
if you're keeping the stock cam you should be fine. should make for a solid 250+ HP performer with plenty of torque and decent mileage.
Old Dec 1, 2014 | 02:36 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
the 96+ requires the vortec specific intake, not sure if you knew that or not
Old Dec 1, 2014 | 02:42 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
As long as you keep the replacement cam at no more than .470 lift there is a lot to be gained by replacing that stock cam. And the stock heads will take that much lift but I wouldn't try anymore.
Old Dec 21, 2014 | 10:31 AM
RQ Jay's Avatar
Car: 1985 TransAm
Engine: 4bbl 305
Thanks for the followups on this, I appreciate the help.
Having checked the block it does have the mechanical pump provision, as well as the hold already drilled.
I intend to send the block out for a rebuild /refresh prior, and will have to make both a cam selection and an intake selection.....I would like to get this to around 300-320 Horsepower, and would like to make sure that there are no hood clearance issues with the Qjet installed.
Recommendations?
Old Dec 21, 2014 | 10:49 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Edelbrock Performer is probably the best you are going to find and keep your hood clearance. I've heard nothing but issues trying to get an Performer RPM working.
Old Dec 23, 2014 | 06:45 AM
naf's Avatar
naf
performer intake is one of only a few available for a spreadbore carb like the qjet.
300 HP is going to require a replacement cam. even if the lift is low I would still recommend a spring replacement. keep it roller.
ensure the fuel pump rod bore is drilled through. seen several blocks that had the hole bored only partway.
Old Dec 23, 2014 | 09:36 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
FWIW, the car in my sig is making about 320 hp through exhaust manifolds with a ZZ3 cam, 1.6 I / 1.5 E roller rockers. Vortec heads are close to stock, only cleanup of bowl area and smoothing around valveguides. Uncut Vortec block, .015" headgaskets, giving a CR of about 9.6:1.
Performer intake, original CCC Q-jet with DR rods / G hanger, runs fine on 87 octane.
Just posting this as concurrence that you need only a very mild cam, especially with headers to make your 300-320 hp target.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
3rdgenparts
Aug 8, 2015 07:09 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
