Holley 600 VS
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Holley 600 VS
I used Sofa's Holley tune last spring to great advantage (recommended, BTW). After sitting for about a month, I noticed the accelerator was sticking. I sprayed the linkage as well as the carb throat. Afterward, the car wouldn't idle until I increased the idle speed. Currently, the car runs well under acceleration, even hard acceleration, but at cruise it bucks/surges like a bronc. Ideas would be appreciated.
JamesC
JamesC
Transmission: 4L80E/4L80E
Re: Holley 600 VS
Have you had it apart since this started happening?
The secondary idle passages are usually ignored because they lack adjustment. Air bleeds are another area overlooked.
I'd start with a disassembly, soaking, thorough blow-out of all passages, then a rebuild making sure everything is clean, clear, and properly adjusted.
Re: Holley 600 VS
I did all this when I did the Sofa tune only a few months ago. Maddening.
JamesC
An easy thing to do would be to get some carb cleaner spray and hit the air bleeds. Can't hurt anything.
Re: Holley 600 VS
JamesC
Re: Holley 600 VS
It does sound like any issue from sitting. If the carb spray had a noticeable effect, that's worth pursuing.
What do you think is the quality of the fuel in the tank? A marginal batch might go south in a months time.
Re: Holley 600 VS
I suspect that during the winter months I allow the car to sit far too long (similar situation a year ago). Bad fuel? Couldn't say.
JamesC
marco33
Jan 14, 2016 12:19 PM
rh76camaro
Jan 13, 2016 11:31 AM
