Fuel Line
Fuel Line
I have an 84 Z28 with a 305. I am attempting to install a new fuel line from the mechanical fuel pump to the q-jet carb however I can not get the routing down right. Does anyone have pics of theirs they can post on here to help me out please?
Re: Fuel Line
So yea the line that came in the mail looks just like that one and I believe it is meant to run behind the water pump. I tried beside it and it almost works perfect but it doesn't line up right into the fuel pump because of the bottom hose coming off the water pump.
Transmission: 5-Speed Manual
Re: Fuel Line
The Water Pump Has To Be Removed To Install The Fuel Line,That Line Is Meant To Go Behind The Water Pump.
Re: Fuel Line
This is all I could find so far.
It will either route inside or outside of the pass side WP mounting leg.
This picture shows outside.
