Removing Rivets on E4ME Choke
Old Apr 7, 2019 | 08:20 PM
DoctorStoopid's Avatar
Car: 1987 Trans Am
Engine: LG4 305
Am an an idiot or is there a trick to drilling out the rivets on an electric choke? I've broken two 7/64 drill bits just trying to drill straight through on these things and all I've done is made a bunch of hazardous metal dust in the process. They're black n decker drill bits, they should be fine - is there another method to getting the black choke housing cover that I could try? Am I just using the wrong type of drill bits? I've never drilled out a rivet before but I feel like there is no way I should be screwing this up this badly.
Old Apr 7, 2019 | 09:48 PM
NoEmissions84TA's Avatar
Re: Removing Rivets on E4ME Choke
You're an idiot! No, I couldn't resist, just kidding.
Do you have a good "feel" when using a drill motor, i.e.- are you in good control of it?
Why so small of a bit? You only want to remove the head of the rivet - no more.
You will need more like a 1/4" or even 5/16" bit. And you don't run the motor at full speed.
Oh yeah, turning clockwise. I've seen people try to drill a hole with the motor going in the wrong direction.
Drill slowly and be ready to stop when the head releases, otherwise you will mess up the choke housing.
Then just tap the rest of the rivet out of the hole with a punch. Good Luck.
Old Apr 8, 2019 | 08:11 AM
Car: 1987 Trans Am
Engine: LG4 305
I'm glad I stopped before I ruined something! I thought the point was to kind of destroy the whole rivet and replace it with a self trapping screw when putting the choke back. How am I supposed to just remove the head without drilling through the entire rivet, though? Wouldn't using a drill bit large enough to do that bust out the sides of the choke housing?
Old Apr 8, 2019 | 06:38 PM
No, you will stop LONG before you drill the choke housing. Once you get through the head of the rivet, it will fall off.
I will do some google searching for a picture.
Old Apr 8, 2019 | 08:19 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The mandrel is usually steel, probably why the bits broke.
Old Apr 8, 2019 | 08:46 PM
Wizz wheel takes about 3 seconds each.
Zzzzzzzzing. Done.
Old Apr 8, 2019 | 09:28 PM
Zzzzzzzzing. Done.
That will work also.
Old Apr 9, 2019 | 06:09 AM
Saxondale's Avatar
Car: 84 Z
Just be very careful. The carb metal drills like butter if you were to overdrill.
Old Apr 9, 2019 | 09:33 AM
Car: 1987 Trans Am
Engine: LG4 305
Those things were a real PIA! The rivets on the cover for the IAB valve were even worse! I had to destroy that little copper cover to get to it.
Thanks for all your help everybody!
Bull86
Carburetors
Jul 28, 2015 11:07 AM
SoSoFresh_SS
Carburetors
Jun 27, 2009 07:48 AM
84z28h.o.
Carburetors
Aug 17, 2007 12:08 AM
camaro87-alex
Carburetors
18
Jul 19, 2007 05:04 PM
ronterry
Apr 24, 2002 08:21 AM
