T-fitting for PCV size?
Old Apr 25, 2019 | 07:05 PM
DoctorStoopid's Avatar
Car: 1987 Trans Am
Engine: LG4 305
I'm in the middle of throwing my (first ever rebuilt) quadrajet on my 305 but it looks like the PO had the pcv hose hooked directly to manifold vacuum where the diagram says it should actually be a t fitting splitting off between the pcv and the EFE tree.
These are wildly different sized vac lines - is there a specific t fitting I will need to make this work? Follow-up, I assume they'll be different size nipples on each side? Would anybody happen to know what sizes both are so I can request it specifically at the store? Thanks!
Old Apr 25, 2019 | 11:44 PM
NoEmissions84TA's Avatar
Re: T-fitting for PCV size?
Without knowing what year your car is, I would say 3/8, 3/8, and about 3/16.
Old Apr 26, 2019 | 07:55 AM
Car: 1987 Trans Am
Engine: LG4 305
Oh wow it didn't occur to me they'd change through the years.
This is an original carb for an 87 lg4
Old Apr 26, 2019 | 12:05 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Is This The One You Mean
Old Apr 26, 2019 | 12:18 PM
Car: 1987 Trans Am
Engine: LG4 305
That's a bingo! Perfect, thanks guys!
Old Apr 26, 2019 | 07:39 PM
Your local parts store should have those in the small packages on the pegboard. Universal fit.
Old Apr 26, 2019 | 08:21 PM
Car: 1987 Trans Am
Engine: LG4 305
As a matter of fact I went to three parts stores today and NOBODY had a t fitting with those specific sizes. I'm actually pulling my hair out over it. Am I doing something wrong?! May just have to wait for Amazon but I was really trying to finish this up Saturday.
Old Apr 26, 2019 | 08:40 PM
Drew's Avatar
How much of the factory rats nest of tubing is still connected? There's no reason the PCV needs to tee into anything. Sounds like the previous owner 'deleted' some of the rats nest. Not much reason to jump thru flaming hoops to hook all that garbage back up.
Old Apr 26, 2019 | 08:48 PM
Car: 1987 Trans Am
Engine: LG4 305
It's all there except this one piece. The previous owner just hooked the PCV directly to the manifold vacuum and the EFE TVS was routed to the vacuum sensor like it should be on one end and the other port was left broken and exposed. I figure i may as well hook it back up the way it's meant to be if this is the only thing missing. As I like to say "I'm building a time machine, not a race car!"
Old Apr 26, 2019 | 09:12 PM
Mine is the same way from the factory as his.
Here are a few diagrams you can use to clean up your hoses, especially if you are deleting some of the emissions components.
Old Apr 26, 2019 | 09:17 PM
https://shop.advanceautoparts.com/we...0f%2Ft%2Fy%2Fx
https://shop.advanceautoparts.com/p/...+f%2Ft%2Fy%2Fx
Old Apr 26, 2019 | 09:52 PM
Drew's Avatar
That last one would be perfect if it included the EGR.
Not really much to do with race car or street car etc... GM was trying to accomplish something, and ended up with a Rube Goldberg mess under the hood. Most of the time, enough of the stuff is messed up, that it's not worth trying to go back. In your case, sure fix it.
Should be an entire rack of vacuum fittings at your local parts store. Blister packed Ts and rubber caps, reducers, etc purple cards iirc.
Old Apr 26, 2019 | 10:24 PM
Last diagram - EGR would connect to "J" via the EGR TVS or EGR solenoid, depending what your car has..
Old Apr 29, 2019 | 07:33 AM
Car: 1987 Trans Am
Engine: LG4 305
Thanks for your help everybody! Got it all hooked up and no vacuum leaks as far as I can see! The rat's nest is complete. Whether that's good or bad is ultimately yet to be seen but so far so good!
Old May 5, 2019 | 02:23 PM
MikeP_82's Avatar
Car: 1982 Camaro Sport Coupe
Engine: 2.8
Transmission: Saginaw 4-spd
My 82 has this one: https://www.rockauto.com/en/moreinfo...GI%2BMXw%3D%3D
OMINOUS_87
Apr 21, 2015 05:17 PM
Tbi-MAX
Dec 16, 2007 10:21 PM
IceManRS305
Aug 12, 2006 08:36 AM
WILL85IROC
Jun 5, 2006 11:11 AM
