Wont start has fuel
Old Oct 31, 2021 | 03:37 PM
Eat_um_up's Avatar
Wont start has fuel
Ive got an 82 305. its got a stock quadrajet on it. Thing ran fine a few weeks ago. Parked it and now it wont start. Thing acts like its not getting any fuel.
If I dump gas or starter fluid down the throat it starts and runs fine until it burns that gas off. Stepping on the gas immediately kills it.
I pulled the fuel inlet line and it pumps gas. I I know gas is getting into the carburetor. My first thought went to clogged idle jet. but something about that does not seem right. It just didn't sit that long. So I thought I would check here for some other opinions. Ideas on what to check out before tearing into the carb?
Old Oct 31, 2021 | 03:49 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Wont start has fuel
Clogged fuel filter?...
Old Oct 31, 2021 | 11:09 PM
Eat_um_up's Avatar
Replaced the fuel filter. So its not that.Sorry, i should have mentioned that in the primary post.
Old Oct 31, 2021 | 11:15 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Stuck needle? Have you tried smacking the carb near the float area with a hard thing?
Might want to tear into the carb anyhow. If you're pumping fuel, and it runs when you put fuel or starting fluid in it, not much else to suspect.
Old Nov 1, 2021 | 04:05 PM
Eat_um_up's Avatar
Haven't tried giving it a smack. Ill give that a shot this afternoon. Thanks for the suggestion.
Old Nov 1, 2021 | 04:51 PM
T.L.'s Avatar
Make sure it's getting spark...
Old Nov 1, 2021 | 05:13 PM
Eat_um_up's Avatar
That it is.If i dump gas right directly down the throat from a gas can it will start and run briefly.
Old Nov 1, 2021 | 05:17 PM
Sounds like whatever is in your carb is not fuel. Probably has water down in the jet wells.
Might want to take it off, turn it upside down, and spray starting fluid (it mixes with both water and gasoline) liberally into all the holes while upside down. Then put it back on and try again.
TheCob
Jul 11, 2015 10:42 PM
09bradyj
Nov 9, 2010 12:50 PM
82karr
Carburetors
Jul 1, 2007 11:14 PM
86White_T/A305
Carburetors
Feb 14, 2002 01:22 PM
silvermelon
Jul 25, 2000 11:54 PM
