I need help I have an 85 firebird transam 305 4barrel carb I've been working on and I swear she just wants to die. I went to chamge oil/scape out and clean the pan and took bolts off pan to clean just to fimd out theres no room to pull the pan off without pulling the motor.but i got a new gasket on ect and thats un related to what i need help with lol just an example on one of the many roadblocks.it hasnt been running besides cranking over for a 10 15 seconds and dieing which is when i realized there was gas in oil.But I keep fixing each problem.she has a rebuilt motor with Low miles on it and its in verry good shape.My latest problem is that I have gas now being dumped or dripped I'm not sure the exact amount but into my oil pan.I know there's gas also in my vacuum lines.Ive read that a bad diaphragm in a fuel pressure regulator can send gas back into the vacuum line?I can't find anywhere online were the location would be for one or it has one in general.Thank you in advance for any help I seriously appreciate it!
Float sticking
Under the air horn
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,486 Times in 1,898 Posts
Bad fuel pump
Rubber diaphragm broken
$20 and 5 mintues
Just do it
Don't argue
$20 and 5 mintues
Just do it
Don't argue
$20 and 5 mintues
Just do it
Don't argue
how can the pump get fuel in the vacuum lines ?Originally Posted by sofakingdom
Bad fuel pumpRubber diaphragm broken
$20 and 5 mintues
Just do it
Don't argue
sofakingdom
close
- Join DateSep 2005
- CarYes
- EngineUsually
Carb cars always get that. It's not meaningful. (unless of course, liquid gas flows out)fuel in the vacuum lines
OP: carbed cars don't have a fuel pressure regulator. Can't be that.
vorteciroc
close
- Join DateJul 2006
- Location212 is up in this Bit@#
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- CarResto-Mod 1987 IROC-Z Clone
- EngineAlky fed L92 Vortec Twin-Turbo 6.8L
- TransmissionMy own built/ design 4L80M
- Axle/GearsCustom 12 bolt (4.10:1)
- Liked:803 Times in 615 Posts
Fuel can get into Vacuum Lines via the Carburetor...
Internal leak or incorrect adjustments can allow Fuel into Vacuum Lines via the Carb.
