Quadrajet to avs2
Old Nov 12, 2022 | 07:32 PM
aj fazio's Avatar
Quadrajet to avs2
Hello so I bought a 85 camaro sport as a project 305 5.0 but I realized I don’t know jack s*** a bout cars so basically I’ve been learning through this car so bear with me I’m switching to a edelbrock eps intake and edelbrock avs2 carb i realized that there’s quite a bit of computer in the car so I was wondering what i need to do to run those parts new distributer ? Or a lot more?
Old Nov 13, 2022 | 12:09 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: Quadrajet to avs2
You stated "I don't know jack s*** a bout cars" . Then why are you trying to out-engineer, the engineers who designed your car?
Why don't you just fix the equipment that GM put on hundred of thousands of 5.0 . Describe the problem/goal and folks here will try to help.
Old Nov 13, 2022 | 07:55 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Very well put. Spot on advice.
Old Nov 13, 2022 | 09:03 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
My apology. I forgot to add:
"Welcome to thirdgen.org"! Please introduce yourself and your car!
Old Nov 13, 2022 | 08:29 PM
aj fazio's Avatar
[QUOTE=mikeceli;6485207]You stated "I don't know jack s*** a bout cars" . Then why are you trying to out-engineer, the engineers who designed your car?
Why don't you just fix the equipment that GM put on hundred of thousands of 5.0 . Describe the problem/goal and folks here will try to help.[/
aj fazio's Avatar
can I just run a performer intake and buy a ccc qjet ?
Old Nov 13, 2022 | 09:03 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
What's on the car now? Standard or automatic transmission? An 85 with a working quadrajet is a pretty decent combination, especially with a 5 speed. .
Old Nov 14, 2022 | 08:45 AM
aj fazio's Avatar
it’s a automatic the only reason I was thinking about changing intake first I already have a new one and the other one has to come of either way it’s filled with rust
Old Dec 1, 2022 | 10:54 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
You can get an edelbrock intake for the spread bore quadrajet. Swapping to an edelbrock and new distributor wont be an upgrade for your car.
To do a computer delete you will need a new distributor and something to do tq converter lock up. Then you will also need a wide band O2 and gauge + vacuum gauge and rod / jet kit to tune the carb
Old Dec 4, 2022 | 10:18 AM
aj fazio's Avatar
yea so i ended up just putting on new intake m and had my qjet rebuilt but I’m starting to think usps lost it😭😭
Old Dec 5, 2022 | 09:33 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Shipping right now is a mess seems like. Wife buys a lot of crap online and it's a daily gripe that stuff is lost or shown delivered and it's still getting shuffled around out there somewhere.
Rayzor32
Carburetors
Apr 27, 2009 04:50 PM
zapr
Carburetors
21
Dec 11, 2004 02:14 PM
War_Eagle
Carburetors
Sep 18, 2003 03:42 PM
jharms
Aug 17, 2001 12:02 AM
Juicer28
Carburetors
Feb 4, 2001 01:03 AM
