Vapor canister
Old May 22, 2023 | 05:26 PM
19eighty4_z28's Avatar
Car: One Chevy built in the 80s
Engine: 5.7 crate
Axle/Gears: Quick performance 9” 3.70
Vapor canister
Just curious if anybody could make me a little smarter concerning the fuel vapor canister. I know what its purpose is BUT is it needed? Or is it leftover 80s emission eqpt? Thanks!
Old May 22, 2023 | 05:44 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Vapor canister
Needed? Depends on if you like fuel vapor smell or not. Still a thing, still relevant. The charcoal absorbs the vapor, the engine then sucks the vapors up and consumes it. Otherwise the vapors just vent to the atmosphere.
Old May 22, 2023 | 05:56 PM
Engine: 5.7 crate
Re: Vapor canister
Copy that. My 84 Z28 still has the original in it from factory. This worth a replacement or ride as is? No known problems other than it’s 40 years old
Old May 22, 2023 | 06:38 PM
Re: Vapor canister
If it's doing it's thing then I'd leave it. People have 'rebuilt' them and changed out the charcoal media inside. A search should yield a how to if you're interested.
Old May 23, 2023 | 03:05 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: Vapor canister
They are still used in modern cars. If you are having canister issues, I verified this for a 1990, you'd have to check wiring diagrams to see if it would work. https://www.thirdgen.org/forums/tech...ter-purge.html
Old May 23, 2023 | 04:39 PM
Engine: 5.7 crate
Re: Vapor canister
I just went and took another look at that thing…the CARB line is capped off. Only the TANK line is hooked up. Not sure why it’s that way to be honest. Never really paid any attention to it before. Ideas, thoughts as to what/why?
Old May 24, 2023 | 07:45 AM
Re: Vapor canister
Why do people come on here and ask WHY humans do ANYTHING?
It's because they're HUMANS, and they're STUUUUUPID, and they're IRRATIONAL, and LAZY, and about a hundred other things that ... aren't nice to say.
In short, asking "why did Stimpy ... do [fill in the blank with random stupidity]?" is simply the wrong line of inquiry. If you were dealing with logic and reason, then going back through someone else's prior decision-making process might yield insights into something you hadn't noticed or thought of or knew about; but in cases like this, it's an intellectual dead end. Wrong question to ask. "Why don't fish use bicycles to get around?"
[/rant mode] The "carb" fitting takes a 3/8" hose that goes to the carb fuel bowl, to catch vapors that might emit from there. It hooks to the big nipple at the very front and center top of the carb.
Old May 24, 2023 | 08:07 AM
Re: Vapor canister
^ That's it there. Probably ignorantly trying to 'fix' something. Or thought it was a performance gain. Just fix it the correct way now.
Old May 24, 2023 | 01:40 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Vapor canister
....... "Why don't fish use bicycles to get around?"......
Despite a well organized campaign, bicycle riding fish didn't make Darwin's last cut, but, , , don't be surprised when gene splicing brings em back on some dark future day.......
ibad57
Feb 26, 2011 07:58 AM
87transam5.7tpi
Aug 18, 2002 09:29 AM
zach
Jun 28, 2002 12:40 AM
HondaHunter
Oct 24, 2001 02:24 PM
