help Q-jet rebuild now SMOKING!!!
Car: 1983 Z28 Clone
Transmission: TH350
hey guys ...my 78 non CC q-jet was running fine until it started flooding real bad.. i've just completed the rebuild ...the car runs but...i'm getting extremely bad clouds of blue smoke..........its soo thick you cant see through the wall of smoke...it seems to pour out worse when i give it some RPM....(throttle) ... any ideas......???the engine will idle fine.....then the idle gets rough and it starts backfireing through the exhaust.....then it will idle smooth again..but it smokes constant...totally undrivable..any ideas.. tips.............it did not smoke before the rebuild..theres only one vac line too hook up...and thats vac advance.. i'm stumped....
thanx guys
Rob
thanx guys
Rob
Re: help Q-jet rebuild now SMOKING!!!
thanx guys
Rob
thanx guys
Rob
Car: 87 Formula
Engine: 327
Have you changed or even checked the oil since the carb flooded over? If it flooded bad the crankcase is probably full of gasoline. The oils so thin now its going right past the rings and youre burning it. If theres alot of gas it can explode and blow the valve covers off so watch out.
Car: 1983 Z28 Clone
Transmission: TH350
the choke is working fine...........i've had a car that had a messed up choke ..........tons of smoke.. tis not the case .....the carb was flooded soo bad.... fuel was just coming out of the top all over the motor.. i had to floor it .....only making like 100 Rpms ... just to get it into the garage... i think that the oil is problebly thinned..its synthetic too........
thanx guys....
thanx guys....
Car: 1983 Z28 Clone
Transmission: TH350
Hey ...i changed the oil wich was black and super thin....i was wondering why my oil level went up..........changed out the oil today....no more smoke ..well... theres a little.. nothing to worry about.....but... i'm still getting some popping in the exhaust while idling....
thanx.....
thanx.....
Car: 87 Formula
Engine: 327
If you had that much fuel flowin your plugs are now wet. Theres at least one thats causing the popping. Pull them all and dry them out. Use carb cleaner and compressed air or maybe a propane torch to dry them.
Car: 1983 Z28 Clone
Transmission: TH350
well... the plugs where black... pulled them...put them back in... the popping is gone ..but i'm still getting tons of blue smoke about 1 minute after startup..
thanx
could a mis-set choke do that ??
thanx
Car: 87 Formula
Engine: 327
Choke will be black smoke. Blue smoke is oil. Does it only smoke for a little while after start up and then quit? If so its valve guides....common problem. If its a continuus blue stream, and get worse under a pull then you have a ring problem. Get the compression tested. Maybe all that gas in the engine hurt something.
Also how long have you run it since the oil change?? The exhaust may be loaded with all the excess oil you were burning. You may just need to take it for a long drive and see if it'll clear up. MAKE SURE YOU STOP AND CHECK THE OIL if it continues to blow smoke. You dont want to run out. I've had some cars smoke for 8 or 10 miles after something like this. If you ever have one blow a gasket and fill the exhaust with antifreeze it creates a hilarious smoke screen for miles.
Car: 1983 Z28 Clone
Transmission: TH350
compression has an average of 150 one cylinder is 139.....doesnt smoke at startup.. i let it sit for one minute ..then it starts smoking.................................
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Its possible that after 1min the exhaust is getting hot enough to start burning off the oil inside. Go for that long drive iff possible and see what happens.
