will i gain power just from switching to carb?
Old Mar 21, 2002 | 11:21 AM
TBI305Camaro's Avatar
exactly what the title says..ill be switches intakes and cams while im doing the swap so i know ill notice a difference from that but is carb really better?
Old Mar 21, 2002 | 01:36 PM
82camaro's Avatar
Car: 82 camaro SC
I carb can respond better to modification like a cam, and can be tuned to work with the modifications. So yes, some of the power will be from having a carb.
Old Mar 21, 2002 | 03:11 PM
Camaro_hunter_d's Avatar
I have been told by more then a couple people that swapping to a carb from TBi will alone gain Hp. Depending on the size carb. Typically anything over 500CFM you'll gain some HP.
Old Mar 21, 2002 | 10:41 PM
i still havent decided what i wanna do yet i may get a 570cfm street avenger if i go carb...pretty expensive swap tho so im not sure if ill be doing it or not
Old Mar 21, 2002 | 11:05 PM
iroc22's Avatar
You will lose torque across the whole RPM range but you'll get a few ponies in the upper RPM's over the TBI unit. Right now it might not be worth the extra cash.......
Old Mar 21, 2002 | 11:06 PM
iroc22's Avatar
oh and its really only necessary to change to carb for extra ponies until you change other things like cam, heads and intake.
Old Mar 22, 2002 | 12:07 AM
84TransAm's Avatar
And on a cold start it will stumble like crazy for usually the first 5-10 minutes of driving.
Old Mar 22, 2002 | 11:56 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
The loss in Torque probably doesn't add up to more than 10 lb-ft. I'd say go for a 600CFM, you'll probably pick up ~10 ponies and most likely it will have improved throttle response and better top end power. You're going to lose MPG of course, but that's how the cookie crumbles.
Old Mar 22, 2002 | 12:06 PM
i plan on changing heads this summer hopefully in june...once i get the heads, intake, cam in i know the TBI is gonna run like ***....id have to have a custom chip so thats why i was thinking about going carb so i can just tune it with tools not computers...
Old Mar 22, 2002 | 06:38 PM
82camaro's Avatar
Car: 82 camaro SC
If you set the choke right you won't have any stumble after a cold start. If you tune it correctly and don't get too big of a carb you won't lose any power on the bottom end. Keep in mind that you must use a different intake/distributer with the carb, and that will affect the whole powerband--you can't just change the tbi to carb by itself.
Old Mar 23, 2002 | 12:37 AM
i know ill have to change the intake and distributer...im probably just gonna go with one of the summit HEI distributers (150$) and a performer intake from edelbrock....only thing is i decided i may still go with a 350 this summer and they sell the one i want for 2200$ thats will all the rotating assembly and heads...the heads are vortexs tho so the intake would be worthless if i do that so i havent decided what i wanna do yet...does anyplace sell 350s with just the rotating assembly? no heads and intake? if i could find one ill just go ahead and put vortex heads and intake on the 305 uintil i get the money for the 350 then swap everything over...what you all think
Old Mar 23, 2002 | 08:59 AM
82camaro's Avatar
Car: 82 camaro SC
Sounds like you are looking for a 350 short block--lots of places have them. If you are talking about the good GM stock heads, they are called vortec.
Old Mar 24, 2002 | 12:15 AM
yeah thats what i meant vortec...i found a L98 shortblock with the crank, rods, pistons for 1100$ i may go ahead and put vortec heads and intake and carb on the 305 and switch it in the future
Old Apr 12, 2002 | 04:06 PM
fordcrusher's Avatar
sounds like a lot of work for a 305
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
89GTAOz
May 16, 2020 09:31 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
