Holley or Quadrajet??
HolleyHolleyHolleyHolleyHolleyHolleyHolleyHolley.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
ICON Motorsports
Holleys are definitely easier to rebuild for a novice. QJets seem complicated to most people the first few times through, usually.
As for performance, I can make ANY QJet run equal to a well tuned 750 vac.sec. Holley. But out of the box, with stock jets/rod/etc most QJets are dogs. Remember that EVERY QJet ever built was from day one an EMISSIONS carb and some of the design of it is just not well suited to performance applications. It's all fixable, but not without some more serious tuning efforts.
94 Firebird Formula M6- No options but Z rated tires. No mods over $10. 13.5@105.
79 Malibu "beater" w/junkyard 400 SBC, tweaked QJet 4bbl, finally a decent set of heads, a few other tricks. A maddening 13.000001 @ 108 on the motor with little traction. No nitrous runs with the new heads yet.
Grandma's old 78 Malibu (33K miles!) soon to have the powertrain from the 79 put in it.
"One of the last remaining QJet tuners on Planet Earth!"
If you go the Q-Jet route, get to know your local junkyard! Go in there and get a bunch of metering rods, jets, hangers, and linkages just in case you bend one by accident. Go ahead and buy a good used Q-Jet for experimenting with as well. Those extra rods can be custom ground but they may erode faster. It never hurts to have a good inventory of HEI springs and weights either!
The Q-Jet would be my choice if you aren't going to stray too far from stock. A properly set up Q-Jet will give you the linear throttle response you want without killing your gas mileage around town.
Transmission: 4L80E/4L80E
Originally posted by Metallica383:
Oh yeah Vote for GORE
Yeah, right!
i'm not american but i shear as hell hope bush wins, i think gore is a lying peiace of crap. "hey look at me, i'm al gore and i invented the internet"
when the green flag drops the bull$hit stops
350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
oh yea. holleys are easy to rebuild. **** i can rebiuld one in 10 minitues(not joking) holleys are finakey as hell. i'm always messin with the needle mixture screws, jets, flote level, idel speed. Q jets are good for relibilty with a bit of performance. i would go with and edelbrock/carter. i just wish the came in more sizes. 500, 625 and 750 cfm just dont cut it.
I am always outside swearing at my Holley. They are easy to get running but fine tuning is pretty hard. Mine is slightly rich or all out lean. Basically performance tuning is easy but mpg tuning is hard. Q-jets are by design gas misers. Holleys seem to dump it in(from experience).
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi
Car: 92' RS Camaro
Holley...
1985 Camaro
74' 355 Small-Block
Doublehump Heads
Holley 750DP 4160
Edelbrock Performer
BlueRacer Cam 232/232
Keith Black Pistons
700R4 w/ B&M Shift Kit
B&M Megashifter
1985 Camaro
74' 355 Small-Block
Doublehump Heads
Holley 750DP 4160
Edelbrock Performer
Keith Black Pistons
B&M Megashifter
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
