Q-jet choke problems
I have a 1986 Camaro with 305 4bbl Q-jet. Recently my choke light stays on
all the time. When the choke light is on my voltage gauge drops to around 10, rather than the normal 14. I have cleand the carb with spray cleaner and used fuel aditive. I'm still driving the car even though it is idling high. Also, the car is running cooler. Any suggestions or information would be greatly appreciated!!
Transmission: 4L80E/4L80E
It's your alternator. For whatever reason, GM tied the "Choke" light to voltage.
You might have another problem or two (like there really is something wrong with the choke), but the voltage dip is a sure sign.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
<font face="Verdana, Arial" size="2">Originally posted by five7kid:
</font>
</font>
thanks five7kid,
the problem was my alternator...i tried checking some other things first but you were correct (see my other posting)...i have also been told that someone's ABS light came on when their alternator went out, go figure!??!... :-)
Glowsock
Sep 6, 2015 06:40 AM
