adjusting the convertible top
Old Oct 18, 2005 | 10:27 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
is there anyway to adjust the top on our cars. the problem that i am having is that the pin that goes thru the tonneau cover is off about a 1/4 of an inch to the front of the car. in order for me to get it in there i need to force it in. i broke the spring clip trying to remove the top once it was in. is there anyway to adjust this. i can post a pic tomorrow if it doesnt rain if that helps
Old Oct 19, 2005 | 12:31 AM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Seems like it would be easier to loosen and move the tonneau cover forward 1/4".. It's like 4 bolts...
Kevin D.
Old Oct 19, 2005 | 07:00 AM
smokefan's Avatar
if i do that than i will have about an 1/2" gap between the tonneau cover and the deck lid. there is about 1/4 to 3/8" gap now.
Old Oct 19, 2005 | 03:06 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
New top? Shrinkage?
It sound like your top is a little too tight.
When the top is put on if I remember right the process is started from the rearmost bow and moves forward. At the front bow (the one that latches to the windshield) the top is trimmed and glued down. If this is the problem the only real FIX is to unglue and reglue it into place...
Why don't you try this instead:
When you put the top up just lay the front bow in place. Don't attempt to latch or even match the pins up. Just lay it up on the latch plates. Then close the Tonneau cover and latch the rear bow. After having done the above Now attempt to line up the latch pins and latch the top into place.
I'm guessing that this will be easier to accomplish than doing the process in the other direction, and that over time your top will stretch out a bit and you won't have to worry about it any more.
Let me know if this helps.
Good Luck!
Speedy
Old Oct 19, 2005 | 03:50 PM
shipfitter_sjd's Avatar
Car: 1992 Camaro RS Convertible & 1983 P
Engine: 305 TBI & 305 4 BBL & 4.7 liter
Transmission: Auto & Auto & 5 Speed Manual
Top adjustment.....
Last year I bought a top frame and new top off of a guy in Buffalo that totaled his convertible. I had to adjust mine to fit right.
The easiest way to do this is to loosen slightly the 4 fasteners (2 on each side) in the convertible well where the top frame is bolted to the body. That plate is slotted and just loosening it will allow you to move your top frame around to get it properly positioned.
You will need to keep the front locked down in positionand slide the top frame back far enough for the pin to properly enter the tonneau cover. Mark it on the top plate and then tighten it down.
Check that it works properly and seats tightly. You may have to do it a couple of times to get it where you want it.
There are also some adjustments that can be made on the rear bows for tightening the fabric. I'll save that for another time.
Good luck and let me know how it goes.
Steve aka shipfitter_sjd
Old Oct 19, 2005 | 04:24 PM
smokefan's Avatar
i tried lossing the bolts and adjusting the top like you said and it didnt change anything. it looks like its adjusted all the way. i need a new top so i think i will wait untill then and have the uphoulstrey guy do it. how much do you think its costs to have a top put on
Old Oct 19, 2005 | 04:34 PM
Tops
Well, I guess it all depends on where you live. Up here there are not all that many upholsterers. I did price it in spring 2004, before I bought the whole assembly on eBay.
I was quoted about $850.00 installed, plastic window, stayfast top.
I noticed that they were particular about the tops because there are like 3 different variations of tops for 3rd gens, and they are each a little different.
Good luck and sorry that didn't help you any.
Old Oct 19, 2005 | 10:44 PM
smokefan's Avatar
thanks for your input though. it is just a pain that it doesnt close. the kid i bought it off of never did anything to it. he just left it like that. when i get more time i will try and figure something out
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
Dan Hubbard
Aug 12, 2015 09:05 PM
