does anyone have some sfc's layin' around?
Old Nov 3, 2006 | 04:41 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I already posted a wanted ad in the marketplace, but I think more of the convertible owners will see this if I post it here. I'm lookin' for a good set of sfc's, used OR new. Preferably UMI or BMR but I will consider anything. The cheaper the better.
Old Nov 3, 2006 | 05:22 PM
W72's Avatar
W72
Car: 89 GTA & 92 T/A covertible
Engine: 408LS-SC, 355 TPI
Transmission: 4L80e, 700r4
Axle/Gears: 12 bolt, 9 bolt
Top-DownSolutions.com
look no further...
Old Nov 4, 2006 | 01:22 AM
BlueZee28's Avatar
Holy wow I didn't know those were that cheap. Hmmmm....Christmas present!
For that price I think I'll get the wonder bar too!
Old Nov 4, 2006 | 05:37 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I didn't realize $184 was cheap, I thought that was pretty expensive for two tubes of metal.
Old Nov 4, 2006 | 08:10 AM
W72's Avatar
W72
It is expensive if you can't afford it...
Old Nov 4, 2006 | 09:20 AM
BlueZee28's Avatar
Well $184 is cheap to me because I thought BMR and UMI and other places sell them for like $230-ish. Either way, I'm gonna try and get it for Christmas so it might be REALLY cheap for me
Old Nov 4, 2006 | 09:46 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
UMI's SFC's are usually $199.99 a set and they are actually on sale for
$179.99 until 11-17.
Do not be a victim of cheaper is better. Spohn, and hotchkis are sometimes cheaper, but if you compare the overall design UMI surpasses them by flying colors. UMI's are specifically designed to clear most aftermarket exhaust and has more surface area to be attached to your frame.
SFC's are usually permanent modifications. If you cannot afford to do it right the first time, can you afford to do it again?
It is a great thing the UMI's are on sale. I give them my highest recommendation. There are many threads, on why UMI is the best.
Take it easy.
-Cale
Old Nov 4, 2006 | 10:25 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
You can see how the subframe connectors are designed to clear my 3" Y-pipe. The passenger side frame is stacked like a reversed "z"
Picture of the driver side. If you look closely at the passenger side you can see the tubular LCA's which are awesome too.
Old Nov 4, 2006 | 10:37 PM
BlueZee28's Avatar
So if UMI is the best stuff out there, where how does Alston compare? Also, I have a cut out installed where my cat used to be, would this be a problem with the location of the sfc's?
Old Nov 4, 2006 | 11:49 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
The cut out would not be in the way as long as you put it where most do. Alston SFC's are comparable to the jegster SFCs reason being... they are the same SFC's. However the popular ones are bolt in. In a short period of time the bolt holes elongate. They can be welded in for better success, however the alston SFC are usually much more expensive. The UMI version still has more welding surface area for increased strength, and a nice red powder coat never hurts the eyes.
Search this forum for UMI... you will not see one... not one bad UMI review on their SFCs every other brand has it's pros and cons. But none as well rounded as UMI's
Old Nov 5, 2006 | 06:21 AM
W72's Avatar
W72
Are the UMI's convertible specific?
I was assuming he was looking for SFC'c that were convertible specific and I can't find where the UMI's are usable in a convertible.
Old Nov 5, 2006 | 02:07 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
i have an extra set of spohns laying around i was going to put them on my red vert,but i decided against because i want to keep it orignal. the spohn subframe connectors are still in the box. let me know if your intrested.
Old Nov 5, 2006 | 02:47 PM
Car: 2012 Corvette
Engine: LS3
Spohn says they won't work on convertables. How much do you want for them irocdx3?
Old Nov 5, 2006 | 06:41 PM
BlueZee28's Avatar
Spohn says they DO work on verts, and I sent you a PM earlier today about them
Old Nov 5, 2006 | 07:34 PM
Car: 2012 Corvette
Engine: LS3
Guess you know something I don't, it says on their web site that they won't fit convertables.
Old Nov 5, 2006 | 08:07 PM
BlueZee28's Avatar
Spohn Performance, Inc.
There's a convertible set and a coupe set. Since he said he bought them for his vert I'd assume they're the convertible set.
Old Nov 6, 2006 | 12:19 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
they don't fit huh! here they are on my vert.
Old Nov 6, 2006 | 07:21 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
-Cale
Where did you find that price?
EDIT - nevermind, I found it.
Quote from UMI site -
"If you are an early Christmas shopper or just like getting a bargain, well now is the time to purchase from UMI Performance! UMI Performance is offering a Pre-Christmas sale and taking 10% off every order placed between Friday October 20, 2006 and Friday November 17, 2006. This includes all UMI Performance products for all makes and models. Some restrictions apply, please see below."
Old Nov 6, 2006 | 08:41 AM
Car: 2012 Corvette
Engine: LS3
Ah, those didn't show up when I searched for them.
Old Nov 7, 2006 | 10:30 PM
nicksL98's Avatar
I have a set of round tube convertible spohn's brand new, For Sale, too....a lot better than UMI birdcrap welded square tubes.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kairles
Oct 26, 2015 09:13 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
BadSS
Aftermarket Product Review
Apr 28, 2001 05:02 AM
