2" drop too much with my wheels?
Old Feb 26, 2008 | 09:47 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I am picking up a set of 2" hotchkis springs for $20 this week from a friend of mine. I couldn't pass up the deal I'm getting. My only concern is that 2" is too low for my car with the 9" wide wheels? Who else is running these springs with wider wheels? Any problems I should be aware of?
Old Feb 26, 2008 | 10:55 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
Re: 2" drop too much with my wheels?
i thought ZR1's only came in 8.5, 9.5, and 11 inch widths. what size tire are u running?
Old Feb 26, 2008 | 11:57 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
$20 is a pretty good deal.
But I didn't know 2" drop springs for thirdgens were ever available from Hotchkis. They currently only show 1", and that's all I've ever seen from them. So if they ever were available, how old(and possibly worn) must these springs be?
Are you and your friend sure they have a 2" drop?
Old Feb 27, 2008 | 12:30 AM
BlueZee28's Avatar
I suppose they could be 1", I don't think they are currently installed on a car right now. They were part of the "extra parts" with a car his friend bought today.
Dan, actually I screwed up my wheels are 9.5" wide. But the 9" version is the original GM wheel that came on factory production cars. 9.5" wheels are replicas like mine.
Old Feb 27, 2008 | 08:33 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Be aware that your stock springs are already sagging after all those years so once you install the lowering springs, don't be surprised if the car sits at the same level or even higher. Seriously. Been there.
Lou
Old Feb 27, 2008 | 10:42 AM
rwdtech's Avatar
lol wow, thats ironic
Old Feb 27, 2008 | 12:00 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have spring tech 2" springs with factory 235/55/16. I rub the tire on the plastic fender all the time. Maybe if I didnt shave the bump stops it wouldnt do that. But then you would have no travel. I have no problems in the rear with an adjustable panhard.
I have some umm.. 1.5" springs that are no longer made(red, forget brand). Never installed. I'm still waiting to get these in.
Old Feb 27, 2008 | 11:54 PM
BlueZee28's Avatar
I guess I'm just gonna have to install them and take it for a drive and see how they are. If i don't like them I'll sell them or something.
Old Feb 28, 2008 | 10:59 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
That is why I want to go with Air Ride...
Sagging? My 87 & 89 are not sagging, they used decent metal on the Pontiacs at least.
I know for a long time back in the 60's Buick made thier springs from a superior metal over Chevy, Pontiac, Olds & Cadillac, They were spending an extra few cents per spring and GM put a kabosh on it.
John
JOhn
Old Feb 28, 2008 | 12:01 PM
BlueZee28's Avatar
John
JOhn
Mine aren't sagging and it's a 100K car
Old Feb 29, 2008 | 05:25 PM
BlueZee28's Avatar
Ok I got the springs today, and the coolest thing was they were free to me for lending a friend my truck....the other cool thing is they are the 1" springs from Hotchkis
Old Mar 3, 2008 | 08:25 AM
okfoz's Avatar
I am not sure but You might end up with more than 1" drop because the convertibe was slightly heavier than a hard top. I really do not know if they changed the rear springs or not. ONe thing that I found on my Convertible is both the rear springs had the same RPO, I never verified this but I thought that my 87 had different RPO's for each side... So I suspect that they changed the springs for the ASC conversion.
It jsut crossed my mind.
John
Scamo-2.8
May 20, 2016 07:01 PM
777Shock777
Oct 29, 2015 04:30 PM
kah992
Aug 19, 2015 02:55 PM
Kaweh
Aug 9, 2015 02:54 PM
