touch screen stereo in a vert?
Old Aug 3, 2009 | 10:34 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'm posting this here rather then audio section because it more pretains to the vert part.
I am wanting to put a touch screen stereo with 7" screen in my vert. Now, I know when my laptop is in the pass seat, I have problems viewing the screen. I am guessing I will likely have same problem with the stereo?
Anyone installed one of these in a vert and have some feedback on this?
Old Aug 3, 2009 | 10:44 AM
*86EYEROK*'s Avatar
Car: 1986 IROC-Z
Engine: 420HP ZZ4 350
Transmission: TH350
Axle/Gears: 4:11's
Re: touch screen stereo in a vert?
they should have a tilt feature on alot of them so the screen can be seen at different angles, i know mine does. i dont have a vert but i got t-tops and i have a hard time seeing mine with the tops out untill i tilt the screen where i can see it. specially when the sun is real bright.
Old Aug 3, 2009 | 10:53 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
i dont have a touch screen but i do have 2 screens hooked up in my vert. 1 in the radio and 1 on the dash. it is hard to see the one in the radio sometimes because of the sun but one on the dash you can see almost anytime. im saving up for a touch screen flip out. if u are going toget one make sure u get one that is adjustable so u can move it a lil to be able to see. also im worryied that with the flip out screen that it wont open all the way because of the dash change for 91 and 92 sticks out a lil more so make sure u measure out everything before u spend the money on one.. be sure to post some pics up. also its a pain in the *** to get things to stay on the dash because NOTHING STICKS to it and i didnt want to drill holes. so good luck and post some pics. also dont forget an alarm system verts are really easy to breakin to
Old Aug 3, 2009 | 01:19 PM
Dale's Avatar
Engine: 350 S-TPI
The radio I'm looking at is the kenwood kvt719. I emailed asking questions, and they said it does have a tiltible screen.
As for clearing everything, I took a small level, and appears the edge of the screen should clear cluster. If not, I have another ride I can put the stereo in. I'm worried about bumping it with the shifter
For anti theft, yes that is a big worry. The 719 has a detach face, aswell a security code. The car is also parked in a garage every night. My work parking lot is small and I get front door parking and its visible the whole time. So that would cover most of the time. But yes an alarm is on the list!!
Old Aug 3, 2009 | 01:29 PM
Engine: ls1 soon
well if it doesnt hit the gauge trim the only problem you might have is that when u start the car the screen comes out it might hit the shifter if u have an automatic.. if u could remember to close the screen everytime u go to shut off ur car that would stop that problem because u would have to hit the button to make the screen come out again but that would be a pain in the ***.
Old Aug 3, 2009 | 01:31 PM
Dale's Avatar
Engine: 350 S-TPI
good point! Its a manual right now, but plans to make it an auto this winter.
Old Aug 3, 2009 | 01:32 PM
*86EYEROK*'s Avatar
Car: 1986 IROC-Z
Transmission: TH350
Axle/Gears: 4:11's
kenwood kvt719..one of my buddies has that flip out screen kenwood and he loves it. good sound quality. like i said before the tilt screen is the ticket.
what kind of alarm you plan on getting? i found that the autopage is one of my favs. the alarm box on the keychain has a window with a car in it and tells you when a door has been open or left open and all kinds of stuff. i had them in stall relays for the the auto window feature so when i arm the alarm the windows go up and when i unarm it the windows go down if selected, perfect if you are in the house and dont have to go roll them up.
Old Aug 3, 2009 | 03:10 PM
Dale's Avatar
Engine: 350 S-TPI
I had a spal before on my show truck, I liked it.
Ive had some other cheaper ones. Didnt have any extra functions like the spal did.
Id like to talk to your friend about the radio. If you would, see if he would be willing to pass along an email so I could talk to him?
Old Aug 3, 2009 | 03:40 PM
Engine: ls1 soon
why would u want to change from a stick to an auto??? i know i would kill to have my auto a stick!! most people change from auto to stick. not the other way around..
Old Aug 3, 2009 | 05:57 PM
*86EYEROK*'s Avatar
Car: 1986 IROC-Z
Transmission: TH350
Axle/Gears: 4:11's
tell me about it, i would give up my th350 for a stick anyday..
what you need to know about that kenwood flip up screen, i can ask him.
Old Aug 4, 2009 | 11:44 AM
Dale's Avatar
Engine: 350 S-TPI
The car was an auto, converted to manual before I got it. The t5 is TRASHED. Easier to find an auto, I know people to rebuild auto, tune is for an auto. And I just flat get tired of shifting gears. Plus few cuties know how to drive manual Even though I offer to teach.
eyeroc..
1. Ability to see screen
2. USB input, whats biggest size hes hooked up/how many mp3
3. Ease of use/user interface
4. How hard was install since its a 2 piece unit?
5. How hot does the 2nd unit get (ventilation needed?)
6. Does he have sirrus/nav/changer/backupcam/etc hooked up also?
7. How long has he had, any problems?
Thanks!
Old Aug 4, 2009 | 12:22 PM
Engine: ls1 soon
for some reason the camaros alway get hot by the radios. i installed 2 computer fans in mine.. it still get hot just not as much and no where near as quick
Old Aug 4, 2009 | 12:44 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I believe my 92 dash is the same as the one in the vert...at least visually it is...not the greatest of pics to see angle but I never have a problem with viewing...however with the top down I can see how it might be an issue...I have tilt on mine, I thought that was standard...
Old Aug 4, 2009 | 05:13 PM
Dale's Avatar
Engine: 350 S-TPI
kris, this unit is a 2 piece unit and the amp setup is what is "remote". I am wondering if under the seat would be enough venting. Then if I have to put it in the "trunk", it gets hot as can be in it.
niterider? Are you full hdtp, or ttop? Looks like it just barely clears the cluster. Any problems hitting shifter?
Old Aug 4, 2009 | 05:33 PM
Engine: ls1 soon
i wouldnt want to mount anything under the seat.. i would put it in the trunk if u cant fit it in the dash. it cant be that bad in there cause i had two 1000 watt amps, a spare battery ,40 farat capp and 2 12in kicker subs in the trunk... man u could feel your scalp tingle with that system, and could hear it doing 70mph with the top down. i took it out after my accident. cause the trunk wouldnt shut. lucky nothing broke but the sub box and batter mount.when it hit the tree.. heres an idea for yea. make a mount in the spare tire well that bolts where the tire would and mount ur amps there. i got the idea from another member on here.
Old Aug 5, 2009 | 08:08 AM
Axle/Gears: Posi
I have a full hdtop and a T Top. The DVD player in the picture is in the hdtop. My unit does not hit anything, shifter or console. And my amp is in the trunk with the subs on top.
Old Aug 5, 2009 | 10:20 AM
Dale's Avatar
Engine: 350 S-TPI
thanks niterider
Kris, how did you run all the wires to that? I'm not seeing a spot to run the wires over the back hump where they wont be visible?
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
okfoz
Oct 13, 2015 02:19 PM
meeklay812
Oct 1, 2015 03:46 PM
Eric-86sc
Sep 28, 2015 11:37 AM
