cheap weatherstriping
Car: 92 z28 vert
Engine: ls6
Transmission: t56 magnum
Axle/Gears: moser 9 inch 4.11
just found super cheap weather striping for convertibles made by softseal the set has everything except the tonneau seal summit has it for 285.99 witch is half to a third of everyone else's price just thought some of you might want to know i just ordered mine this morning the part number is sft3187
Car: 92 z28 vert
Engine: ls6
Re: cheap weatherstriping
i forgot, it is not on the website yet softseal just came out with it summits part number is sft3187 you will need to call them to order it. to see what you will get, get on softseal.com and put in 3187 in the search
Car: 91 Firebird
Engine: 6.0
I did find it on the Soffseal website, listed for $555.40
http://www.soffseal.com/store/main.a...tail&item=3187
and just the header seal for $291.10
http://www.soffseal.com/store/main.a...tail&item=3186
Car: 92 z28 vert
Engine: ls6
yes that is retail call summit and tell you want the price on part number sft3187 they will tell you 285.99 their phone number is 1800 230 3030
Car: 1990 irocz camaro
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.42 posi disc 10 bolt
they over charging , shop around and look at all sources they make up there own prices and you will be amazed at what prices are going for in different stores
Car: 92 z28 vert
Engine: ls6
i just received my weatherstriping yester day and it looks great it even looks better than the factory stuff the header seal fits great
Car: 1987 Trans Am
Engine: LQ9/L92
just a little side note - the soffseal kit does not appear to include door seals, sweeps, or the triangle seals. we've got a kit with everything in it together, but i'm working on getting you guys a price for a comparable top-only kit to match the contents of the SS one noted here.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
What does the SoffSeal kit include... I am interested in a kit that includes all of the convertible specific parts... I have brand spankin new (really pricy too) GM window sweeps, The Door seal I got from SS was actually long ( i installed it on my 87 Formula, about 1 inch in the front part of the door, so i a little leary about SS...) i would be interested in a review of how well they fit. I have not heard great things about the Metro stuff either, but that was 3rd hand, and someone did say they had good luck with it...
At any rate, I need the window seals around the door windows, the rear seal around the tonneau, the rear top seal, and the rear trunk seal, as well as the windshield header... The Door seal would be a nice perk, but the rubber triangle??? really not sure if I need that or not...
John
John
Car: 92 z28 vert
Engine: ls6
The soft seal comes with the header seal the window seals and the rear top seal and that is it they don't make the tonneau seal yet you are the first that I have heard of that has had problems with softseal pieces I have used many seals from them along with my family and friends and have never had an issue I seen the tonneau seal on eBay for like 50 or 60 but have not ordered one yet
The SS stuff was not bad mind you, just 1" or 1/2" long in the front of both doors... So I had to finagle it to get it a bit... I have had SS before on other cars and it is usually ok, not as good as OE, but by all means passable as a decent product...
I want to think the rear trunk seal is the same as the rear hatch seal on the hardtop cars, Just shorter... I have not even looked at the rear tonneau seal to see if they were smart enough to do the same there...
John
John
Car: 92 z28 vert
Engine: ls6
the trunk seal is the same for hard top and convertibles just shorter but the tonneau seal is different
I wondered, thanks
John
John
Does it come with the rear bow seal or not?
thanks.
John
Car: 92 z28 vert
Engine: ls6
yes it does my kit came with all of it, the header,vertical,horizontal and rear bow seal
Car: 1988 IROC Convertible
I am rather confused about the ad. It states that it comes with the windshield, and the horizontal and vertcal and rear bow... So that to me would be 6 pieces. I went to Soffseals website and it does not show the rear bow seal.
thanks.
John
thanks.
John
Here: http://www.soffseal.com/store/main.a...tail&item=3187 The img does not show the rear seal
Summit has it on their website here: http://www.summitracing.com/search/?...=sft3187&dds=1 no image
John
John
I checked 1A... as I have done business with them before, and no luck, I could not find it... I found a hard top window seal that included the door, but that was it...
I was hoping to get a complete kit...
Oh well
John
Oh well
John
An update...
I just received my order, and yes indeed the kit includes 6 pieces.
1) Windshield seal
2) Pair of rear door window seals
3) Pair of upper door window seals
4) Rear bow seal (which I did not have at all...
So it does the entire top...
Looking at the pic, it shows it, but it is mixed up with the windshield header...
John
1) Windshield seal
John
Damon
Sep 26, 2015 04:29 PM
