rear speakers in a vert
Old Apr 27, 2011 | 08:06 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
what rear speakers are you guys running in your verts? i went on crutchfield and they recomend round speakers but the hole is big enough for a 6x9. now the problem is the botton depth, to run a 6x9 it would have to be pretty damn shallow. so what rear speakers are you guys running?
Old Apr 27, 2011 | 05:39 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: rear speakers in a vert
FYI . . .
https://www.thirdgen.org/forums/car-...nvertible.html
https://www.thirdgen.org/forums/car-...-speakers.html
Old Apr 29, 2011 | 12:20 AM
84 Lemon Drop's Avatar
Car: 84 z28 convertible
Nothing in the trunk, kicker in the back of this guy, loud as you want it
Old May 11, 2011 | 09:11 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
My '91 TA had 6 1/2" rounds as the stock rear speakers. I have replaced them twice - first at 8 years with Rockford-Fosgate then 5 years later with Polk Audio. These were also 6 1/2" rounds. The Rockfords fit the narrow depth needed without modification. The Polks fit but I needed to fab a spacer to move the magnet towards the inside of the car.
I drive them with a 260 watt amp in the bottom of the trunk well along with a 10" sub. Sound is high quality and cuts through the road noise on the interstate with the top down.
You will find that the speakers are different for different years even though all were installed by ASC when converted to a vert.
Old May 28, 2011 | 07:38 PM
mudd746's Avatar
Car: 89 IROC Convertible
Engine: 305HO
https://www.thirdgen.org/forums/conv...ar-panels.html
Old Jun 24, 2011 | 08:33 PM
limitlessfbody's Avatar
Car: 91 RS CONVERT.
Engine: 5.0
Transmission: AUTO
ok i know theres a ton of post but there all dated way bak and i couldn't get a response on the last thread. Ive got the vert with memphis 6x9's i know the depth is a problem from the post, but does anyone know how much depth you need? I just order inch and a half spacers so im hoping they will fit
Old Jun 26, 2011 | 06:51 AM
Car: 91 Trans Am
Engine: 355 TPI
depends on how deep the speakers are.....inch and half may or may not work
Old Jun 28, 2011 | 07:51 AM
Car: 91 RS CONVERT.
Engine: 5.0
Transmission: AUTO
Ok i got my 1 1/2 spacers yesterday so i ripped my rear panels off. The previous owner had house speakers screwed in behind the panels lol. my Memphis speakers are 3 1/2 inches measuring from the mounting surface to the bottom of the magnet. and with the spacer they fit good, ill have pics up tonight
Old Jun 28, 2011 | 10:42 AM
jstanfi1's Avatar
Car: 1992 T/A Convertible
Engine: LB9 305 TPI
Similar question I guess...where are you guys mounting amps in these cars? I'm wanting to keep the factory look so I'm using the factory HU, but I thought about using a harness to wire an inline amp to improve the sound along with some new speakers. Thoughts?
Old Jun 28, 2011 | 01:54 PM
Car: 91 RS CONVERT.
Engine: 5.0
Transmission: AUTO
im putting mine in the spare tire well
Reddeath210
Oct 6, 2015 08:20 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
89lsc
Aug 14, 2015 04:58 PM
