vinyl film?
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
vinyl film?
I don't own a convertable, so be kind to me, I don't know all the terminology...
yesterday I was helping a friend primer his vert, and when I was sanding I found a vinyl film on the area in fornt of the trunk. It was in terrible condition, so it had to go.
First of all, what was that?
Second of all, why is it there?
third, when we paint the car, do we need to replace it
Forth, where do we get it?
Here's a picture of the after shots... I think for primer, they turned out great
the first shot is the area I'm talking about
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: vinyl film?
I just searched 'convertible top vinyl' & the top result was: https://www.thirdgen.org/forums/conv...s-finally.html
Re: vinyl film?
thanks, but if you read that thread, it's not of much help... hope he's ok, I'm certainly not going to bother him about something like this.
Car: 1989 RS Drop-Top
Engine: 305 TBI
Re: vinyl film?
jstoltz is the name you are looking for. He has designed and manufactured the strips that you are inquiring about. They are a must to keep the top from rubbing the paint when in the up position. They are very well made and easy to install. I installed a set on my 89rs about a year ago and fit perfect. In this case I don't think bothering him is a problem....
Re: vinyl film?
he doesn't seem very responsive to posts on that thread, but at least that's an option.
Car: GTA
Re: vinyl film?
If you do not want to respond to a For Sale post? That is your choice. If there was something in the thread about him that indicated that there were problems with him? It is your call to make.
I did give you the Search criteria I used, so maybe that will help you find another thread that contains the info you want.
Re: vinyl film?
well I did search on ebay, hawks, camaro central, and a few others to see if I could find it. I'm not against buying it from somebody here, but the guy doesn't seem to be on here very much, so I'm not going to recommend him to somebody else.
If they are that hard to get, do most people do without them in a restoration? what's normal?
Car: 88 Iroc-Z Convertible
Re: vinyl film?
I'm talking to a guy now with a vinyl cutting machine. He thinks he has the same material jstoltz was using. GOtta figure out a way to get him dimensions if he cant find a car locally to measure off of. If anyone knows someone with a convertible in Tampa bay, let me know.
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
Re: vinyl film?
It is for sale on Ebay now! Search for 92 camaro convertible tonneau decal and you will see it. It sells for 139.99$ You can also send an email to modern day muscle car previoulsy know as perrypam.com, they may have some more left...
Car: GTA
Re: vinyl film?
Re: vinyl film?
http://www.oracal.com/products/_docs.../Series851.pdf
951 would work as well.. more expensive though, probably not worth it.
Car: GTA
Re: vinyl film?
oracal 851
970RA is double the thickness, 10yr life (like 851) but I don't see Clear listed for 970RA.
751 is only 1 yr less than 851.
Re: vinyl film?
I wasn't looking at the standard, thin skins. Only 2 mil. 7510 would be great, 6mil thick, but only comes on fluorescent. 851 is all I ever use for window decals, unless somebody wants fluorescent/metallic/etc.
Re: vinyl film?
does your set include the little side pieces?
I'm probably looking in the wrong spot, but mine looks like its only one piece.
Engine: 305 TBI
Re: vinyl film?
[quote=Impaqt;5057317]What exactly are these "Little Side Pieces"?
There are two small pieces that go just ahead of the cover. On the post just behind the door
Car: GTA
Re: vinyl film?
I'd rather go thicker & just do it once. Sign vinyl is not made for wear resistance, so it is not as wear resistant like the material made for this purpose.
Re: vinyl film?
but it looks better. I dont know about all Convertible 3rd gen Camaro owners, but I gotta imagine most are not daily drivers nowadays where we are taking the top up and down on a regular basis.
Re: vinyl film?
getting back to one of my original questions... are these things standard on ever convertible restoration, or do some people just do without?
Re: vinyl film?
Car: GTA
Re: vinyl film?
Ans up/down is not where the wear would be occurring, but rather while it is up & driving, as the top shifts.
Sorry 58mark for getting slightly off track. I know vinyl & subjected to the constant rubbing of a top shifting while the top is up is not something I would recommend standard sign vinyl to be used for & certainly not the 2ml stuff.
Car: 89 Iroc Convertible
Re: vinyl film?
I have a nice tonneau cover from a jy vert and I started to peel the vinyl up just a bit.Looks like it will come off in one piece.Can this be reapplied to my own car?
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: vinyl film?
cthe ones that were on ebay are gone. sometimes you can find NOS wear stickers (rarely) for around 200$.. I believe that is what modern day muscle had.
the ones that were on my cars are destroyed from the sun, cracking, yellowing. Im not interested in 20 yr old vinyl technology. im looking for more of what they wrap cars with now.
jstoltz was selling new versions, but idont know if he is going to making anymore.
If anyone finds any let me know im still in need.
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Re: vinyl film?
I just purchased the one on EBAY for $100. I will update you once I receive it.
Car: 90RS Conv.
Transmission: th400
Re: vinyl film?
sounds like there's a market there for somebody else to start offering it... maybe somebody here could provide the service and make a buck at the same time
it's funny, I find this discussion very interesting, and I don't even HAVE a vert!
Car: 90RS Conv.
Transmission: th400
Re: vinyl film?
thanx...
you got a original, for 100$. good deal. Reads like its already yellowing tho.
58mark does have a point, and you have a pattern,......food for thought.
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
