How do you access the rear speakers?
Old Feb 6, 2013 | 04:27 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Do I pop off the grill from the inside or pull up the carpet from the area where the vert top folds into?
looks like a bitch
Old Feb 6, 2013 | 06:32 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: How do you access the rear speakers?
You need to remove the armrest panel they are mounted on and then the grills and speakers can be taken off of the rear of the panel. Not hard. Just remove the trim along the door jam edge, the plastic cap on top by the end of the tonneau cover, and the srews along the rear edges hidden by the upper seat sections. Be careful not to break the seatbelt slot trim piece when you take the panel out. Oh, and disconnect the interior lamp that is also mounted on the panel.
Old Feb 6, 2013 | 07:30 PM
insomniac's Avatar
Engine: 5.7 L98
so they come out from the inside or pull ou from the back?
Old Feb 6, 2013 | 07:40 PM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
On my car, the grills and speakers are on the same studs. Take the panels out and then loosen the mounting hardware and the grills, along with the speakers, will fall off.
Old Feb 12, 2013 | 02:29 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
A phillips head screwdriver goes a long way.
Old Feb 12, 2013 | 02:31 PM
insomniac's Avatar
Engine: 5.7 L98
what the hell is a screw driver?
Old Feb 13, 2013 | 12:52 AM
abray1's Avatar
If you don't know I can't explain it.
Old Feb 13, 2013 | 06:39 AM
insomniac's Avatar
Engine: 5.7 L98
oh ok i get it
Old Feb 19, 2013 | 12:32 AM
abray1's Avatar
I like your screwdriver better than mine. Does craftsman sell those?
Reddeath210
Oct 6, 2015 08:20 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
89lsc
Aug 14, 2015 04:58 PM
