tinting convertible rear window
Car: 91 firebird vert
Engine: 305 tbi
Hey id lije to tint my convertible windows. I have the hard plastic rear. Is it ok to tint it? Just wondering from people who have done this. Thanks!
Car: 85 IROC / 92 Z28 Vert / 57 210
Engine: L69 / LB9 / LQ4
Transmission: T5 / T56 / 4L65E
Axle/Gears: 3:73 / 3.73 / ?.??
Re: tinting convertible rear window
The only real way to tint a plastic back window is using that spray stuff people use on tail lights. Probably won't look good though. Most tint shops won't tint plastic windows because the film won't have the same effect as on glass windows. For example the expansion contraction of heat and cold will be different then the tint, the window may get folded, etc all these issue can cause the tint to form bubbles, get creased or have the glue pop. Best thing is to wait till you replace the top with a glass rear window, then have it tinted.
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I wanted to tint my plastic window too, but was told that it will fall right off of the the window after a few days.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I would be afraid to do that, especially if the window tinting is not compatible with the rear window. Some plastics do not like other plastics, I have seen one plastic actually deteriorate another plastic because as it gasses out, the fumes from one attack the other.
John
John
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
has anyone ever tried the vinyl cling for glass.I thought about getting a piece but never got around to trying it.
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
I had the factory worn plastic window replaced with a tinted plastic one. it looked nice but I could hardly see threw it, and since it was thinner, it didn't last long... If you really want to have your rear window tinted, get the top with the window glass and then you can tint it!
Car: 90RS Conv.
Transmission: th400
i second that. i went with the glass window. Ill never go back to the plastic
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
You have info on converting to glass? Im thinkin of trying and just starting to gather info
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Car: 88 Iroc vert
Engine: 305 tbi
Car: 88 Iroc vert
Thanks for that link. I already have a new robbins top recently installed. Im looking to convert to glass like i have seen on here.
Car: 88 Iroc vert
Good to know. If i csnt some how adapt mine i will have to go that route.
I wonder if they just use the same glass as a 4th gen...
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
You can't use plastic window tint on plastic windows (See question 4)
http://www.gilafilms.com/en/Auto-Tint-FAQ.aspx
I plan to re-top mine probably in the spring and I had planned to go with the glass. I know that it's shorter but has anyone had a problem with breaking one when they are putting the top down.
Car: 90RS Conv.
Transmission: th400
I believe your right. i remember reading the same thing, but I dont have rear seats anymore, so i cant confirm that. But it does fit nicely between my rear rollbars.
Engine: 305 TBI
That's not a problem as I keep my seats folded down all the time anyway. I've seen too many of them dry rotted at the top by the sun.
Car: 1991 Trans Am convertible
I have a convertible top with the glass window and you do have to drop the seat only about 5 inches. No need to fold it down all the way.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
