1991 Z28 convertible trunk lid issues?
Old Mar 20, 2014 | 04:06 PM
madness's Avatar
Car: 1991 Z28 Convertible
Engine: 5.0 TPI
Transmission: 5 Speed
Hello, I am new to the forums I recently purchased my midlife crisis, a car that I have wanted since since highschool. A nice red 91 Z28 vert with a 5 speed, the car is in pretty good shape except for the trunk lid rubbing against the tonneau cover. I read a few posts on this issue but I still cannot slide (adjust) the lid back? does the u brackets themselves have adjustment or do I need to beat them into submission? I will post pics of my restoration as time and money allow. Thank you for any help you can offer.
Old Mar 21, 2014 | 12:08 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: 1991 Z28 convertible trunk lid issues?
Look at how they adjust. You may need to take them apart and grease them or oil them since they are getting old. Remember that you can adjust the trunk at the hinges and the striker. I havent looked at where you adjust the tonneau. My midlife crisis is a triple black 92 25th.
Old Mar 21, 2014 | 03:01 PM
madness's Avatar
Engine: 5.0 TPI
Old Mar 21, 2014 | 05:37 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
4 bolts on the trunk lid on my 90 midlife crisis, I just loosened them and yanked the lid back, snugged up.
Old Mar 22, 2014 | 10:46 PM
madness's Avatar
Engine: 5.0 TPI
Thanks tried that but I'm pulled all the way back and I still need 1/4 of an inch to line up correctly? Nice vert
Old Mar 23, 2014 | 04:02 AM
abray1's Avatar
You can do the old trick of getting a drill bit and grinding the holes a little oblong to get more clearance.
Old Mar 23, 2014 | 09:18 AM
Car: 90 Iroc Vert
Engine: 5.0L
Does the tonneau need to come forward ? - check the alignment.
Old Mar 23, 2014 | 07:20 PM
TRANSAM82-92's Avatar
There's a spring located under toneau. If you open trunk you can see it right behind toneau. If a bolt comes loose it will be misaligned. i know because it happened to mine.
Old Mar 23, 2014 | 08:32 PM
madness's Avatar
Engine: 5.0 TPI
Thanks trans am 82-92 I will check the guy I bought it from said the trunk needs to come off to put the top down? The tonneau seems to be in the right spot. He said they used it a lot for parades and I figure maybe all the weight messed something up?
Old Mar 23, 2014 | 08:35 PM
madness's Avatar
Engine: 5.0 TPI
I read that if the shocks were bad it could affect adjustment so I guess I should order those as well
Old Mar 23, 2014 | 08:39 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Don't drill anything. Something is misaligned. adjust the tonneau and deck lid. It takes time to get just right.
Old Mar 23, 2014 | 08:59 PM
madness's Avatar
Engine: 5.0 TPI
Thanks I had a hard time finding on and I don't plan on drilling
1992 Trans Am
May 10, 2023 07:19 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
69 Six Pack
Oct 5, 2015 07:51 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Cripley
Aug 17, 2015 03:35 PM
