Subwoofer enclosure
Old May 28, 2023 | 04:46 PM
jimmylev's Avatar
Car: 89 IROC Vert
Engine: 5.0
Transmission: 5spd
Subwoofer enclosure
I have an 89 vert camaro. The top is down 100% of time but don't want to remove it in case I ever get caught in rain. Saying that, as the top is down I assume having a traditional box in the well will not be a good option due to the top muffling the sound. Has anyone done anything such as a box in the space occupied by the unusable rear seats? I was thinking about gutting a seat-back and putting in one of those under seat boxes.
Any suggestions or recommendations for getting some bass ?
Old Jun 4, 2023 | 02:36 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Subwoofer enclosure
I used to have this in my spare tire well, but i eventually decided id rather have a spare instead.
So i switched to these two 10" subs instead. Its just a piece of wood that fits halfway down in the trunk on the little "shelves" on each side of the trunk. It's not as dedicated as a box, but they're more than enough for my needs
Old Jun 4, 2023 | 04:45 AM
jimmylev's Avatar
Car: 89 IROC Vert
Engine: 5.0
Transmission: 5spd
Thanks for the response. How was/is sound with both of these with top down?
Old Jun 4, 2023 | 11:29 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Virtually the same, the bass is'nt affected much. Maybe the high's a bit when the top is down since my 6x9s are right behind it, but i still have 5.5" speakers in the rear seat panels
Old Jun 4, 2023 | 12:30 PM
jimmylev's Avatar
Car: 89 IROC Vert
Engine: 5.0
Transmission: 5spd
Can you upload some photos of what you've done behind the seats. Surprised to hear that the subs are not affected by the top being down. I keep reading the sound is significantly impacted
Thank you for your input
Old Jun 4, 2023 | 12:54 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
That's about the only pic a i have of the subs. I haven't done anything behind the seats, just the trunk. The difference is mostly from the exposed interior when the top is down. Some of the bass goes outward, but even more noticeable is the higher frequencies are blocked because the top is literarily about 1" from the 6x9s. What does affect the subs/bass is if you open the trunk.
NeNick95
Car Audio
May 23, 2012 10:16 PM
1meanGTA
Car Audio
Jul 18, 2005 10:17 AM
hawkeyeZ28
Car Audio
May 12, 2003 08:43 AM
87 B4Z
Car Audio
Mar 29, 2002 04:41 PM
I ROCK
Car Audio
May 27, 2001 09:57 PM
