40* below
Old Jul 19, 2002 | 09:18 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
40* below
I was in autozone and saw a product that says it will cool your motor down anywhere rom 20-40*. It is $19.99. All you do is add it to you coolent. Has anybody tried this? Does it work?
Old Jul 19, 2002 | 11:56 PM
Sciguyjim's Avatar
It's probably something like "Water Wetter" made by NEO or Red Line, I forget which. It (Water Wetter) seems to really help heat transfer. I haven't heard anything bad about it.
BTW, it supposedly cools the engine 20° to 40°. It doesn't cool anything to "40* below".
Old Jul 20, 2002 | 02:00 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
I've tried that "40 Below" stuff and also "Redline Water Wetter" but, didn't notice any real improvements. They're supposed to also eliminate hot spots in the heads which they might do. From now on I've found that a 70-30 mix of coolant works well for my 305 tbi where I live.
Old Jul 20, 2002 | 02:14 PM
Sciguyjim's Avatar
I've tried Keep Cool from Redline and Water Wetter but didn't see any noticable improvement. I've seen them recommended on some forums though.
Old Jul 28, 2002 | 06:17 PM
88Bravo's Avatar
So I guess the stuff doesn't cool the motor, it just might reduce hot spots in the head. And I also take it that the 70-30 mix is coolant 70%. Just making sure. thanks for the help.
Old Jul 28, 2002 | 07:09 PM
GKK's Avatar
GKK
The 70/30 coolant mix is 70% water and 30% antifreeze. Water absorbs heat a lot better than the antifreeze The antifreeze just raises the boiling temp of the water and helps lubricate the cooling system.
Old Jul 28, 2002 | 09:44 PM
iroc22's Avatar
Water Wetter is made by Redline Synthetics. I run it with straight water and my car never sees past 195*, even with no air damn on the freeway. I think it works really well.
Old Jul 29, 2002 | 02:46 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
Water wetter by redline works great. It droped the temp on my maro 15-20* F
