Compressor Question
Old Jul 26, 2002 | 10:08 AM
FastKitteN's Avatar
Car: 1988 Camaro
Engine: 5.7liter v8 (LT1 carb)
Transmission: th-350 rebuilt with a 2400-2800 stall
Compressor Question
I'm looking to buy an a/c compressor for my 88 2.8liter v6 camaro. There is a guy who is going to sell me a compressor from a v8 with the pulleys too.. My question is will this work? Are they pretty much the same? Someone told me you couldnt take a v8 compressor and put it in a v6 so im not sure. The guy i might be buying this off of said he thinks it will work but isnt sure. And so I thought I would post here to see what ther professical think .....
Old Jul 26, 2002 | 12:09 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
at one point I was going to use the compressor out of my v6 sc on my v8 iroc, I cant remember if I did or not...brain fart...check the model numbers on the compressor if its a Harrison/Delco with the sticker still on it. Barring that...eye ball it...are all the connections the same? the mounting holes in the same place...is it the same pulley...etc etc
Old Jul 26, 2002 | 12:37 PM
FastKitteN's Avatar
Car: 1988 Camaro
If I had some to compare I would.. My car didnt come with one and I cant see the v8 one because I believe the guy lives in Texas.. Hmmmmm....
Old Jul 26, 2002 | 12:49 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
if it is out of a v8 camaro...close to the same year, I think you may just need to change the pulley....my 85 v6 and my 85 v8 had the same mounts, same basic compressor...did your car come with a/c? or is it just missing the compressor?
Old Jul 26, 2002 | 12:56 PM
FastKitteN's Avatar
Car: 1988 Camaro
It used to have a/c before I got it. I found out that before this one person sold it to the people i got it from they took out the compressor since it was new. So I am left with no a/c. I beleive the guy said he's giving me the compressor and pulleys from an 89 v8.
Old Jul 26, 2002 | 01:12 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
is it a serp belt or vbelt? you will probably need to get a pulley from a 6..i think the belts are a different width. Also are your a/c hookups to the compressor still there? like the lines from the comp to the dryer, etc.? is your compressor bracket there....I think the compressor may work at least going by my somewhat faulty memory...but you may need more parts. If its cheap enough though go for it....but I would shop around local first.
Old Jul 26, 2002 | 01:43 PM
FastKitteN's Avatar
Car: 1988 Camaro
Hmm good points. I cant look at the car right now to tell you.. Its 3 1/2 hours from me.. It has a serp belt. I actually have the belt for the a/c and air pump i guess right now the belt is way too long. Apparently if im right my husband said they cut off the compressor... He's told me I could have the compressor and pulleys for 35.00 plus shipping I believe..
Old Jul 26, 2002 | 01:56 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
well 35 bucks aint too bad, junkyard here charges about 30 and you have to pull it....if they cut the a/c off you are going to have to find new brackets for the v6....hmmm you might wanna try some of the boards sponsors for that
Old Jul 26, 2002 | 02:05 PM
FastKitteN's Avatar
Car: 1988 Camaro
Hmmm lets see I posted a classificated ad and I've gottin a few responses heres some
Heather, I have an 87 iroc i just removed the engine from. i
will sell compressor for 40
I have a compressor with the pulley brackets, I would give it to you for
35
plus shipping costs.
This one is from a v8.
Bessler's u pull u save had a used one for 49.00.
www.Besslerauto.com
So I dunno what to do. Are you bored at work too? jk
Old Jul 26, 2002 | 02:15 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
actually about to leave from here....are there any u-pull-it yards in your area...it would be a good place to get the hoses, bracketry and pulley you'll need....compressors run like 60 bucks reman, and 150 new...something like that. so if you can get a working used one for under 40, cant beat that, especially if the hardware is attached. plus you'll want to get a kit to convert it to r134..they sell for like 10 to 20 bucks at the parts stores...so you can get it charged without having to sell your first born
Old Jul 27, 2002 | 06:14 PM
FastKitteN's Avatar
Car: 1988 Camaro
Anyone else know??? There's im sure a pic of my engine on my site not sure if you can see where the a/c stuff is suppose to go or not but im not sure what all i need.. Plus I still dont know if a v8 compressor will fit my v6..
Please help!
Old Jul 28, 2002 | 12:54 PM
FastKitteN's Avatar
Car: 1988 Camaro
Anyone? I really wanna know...
evilstuie
Apr 14, 2016 08:52 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 25, 2015 07:34 PM
redmaroz
Aug 16, 2015 11:40 PM
rh76camaro
Aug 15, 2015 12:48 PM
