no air dam
Old Oct 16, 2002 | 01:57 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
no air dam
will this cause the car to overheat?
i know the lower air dam is supposed to keep the air from going underneath the car
im trying to diagnose an overheating problem on my z,
i know the coolant level is fine, and the intake was resealed a while back
next goes the water pump, i guess
Old Oct 16, 2002 | 02:10 PM
KlayBuRn's Avatar
We need a sticky on this board, KEEP THE DAMN AIR DAM ON@!#$
Old Oct 16, 2002 | 04:43 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Can anyone tell me if the air dam for an 84Z-28 is the same as later model 3rd gen cars ? I look under mine and the dam looks like a mild shaped V made out of something that looks plastic, but at the local car club here I look under a couple of later ones and they look very staight a rubbery. Maybe mine is original and theirs is not? Mine also has a split in the middle of the V. Any help?
Old Oct 18, 2002 | 04:50 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Agreed
Old Oct 18, 2002 | 12:58 PM
iroc22's Avatar
I've never needed an air damn, however I seem to be the only one.
Old Oct 18, 2002 | 01:15 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
air damn
Cracks me up when people say that, makes me wonder if the spelled it that way on purpose...
Old Oct 18, 2002 | 03:04 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
dont listen to this guy
Old Oct 18, 2002 | 09:00 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I just found out that I don't have one anymore on my car. My car runs around 220 all the time never goes over but it also has a 160* thermo and the fan was changed to come on earlier so I think that is keeping me safe. But I still am getting a dam as soon as I can.
Old Oct 20, 2002 | 02:01 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Yeah, I would say get one... when I bought my car it didn't have one on either going down the highway I would run like 220-230 degrees but once I stopped it would redline on the gauge and boil the coolant out.
Old Oct 22, 2002 | 06:49 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
perhaps that is how the previous owner of my z overheated it, blew out the intake gasket, and pretty much ruined the engine.
the engine still runs, but its got bearing damage, and overheats pretty bad. hopefully i can find one in a junk yard, b/c i think that they are like $60 plus dollars new
the rs i just bought has one on it, and it runs right at 160, but i think im goint to put a 180 stat in it since winter is coming
Old Oct 22, 2002 | 07:12 PM
f0rmula350's Avatar
word
Old Oct 23, 2002 | 11:51 PM
breathment's Avatar
i thought about making a sticky that had common cooling problems, with the electrical cooling system diagrams too.. but everyones questions would be answered in there and they wouldn't have any reason to post a repetitive question..
but if u guys really think we should, then we can put together a post and make it sticky. we would jjust need to make sure its organized..
Old Oct 24, 2002 | 12:59 AM
spitz74's Avatar
The air dam is NOT to keep air from going UNDER the car (in an aerodynamic sense). It's to funnel air INTO THE RADIATOR. The vent in the front facia is for looks. It is almost entirely blocked by the license plate shaped reinforcement behind the vent insert. If you have the Z28 driving lights, then it's nearly completely blocked. The only air the radiator gets is what is directed from under the front chin spoiler, up by the air dam, and into the radiator. Without the air dam, the fan has to do all of the work of pulling the air through the radiator (not so bad if you have dual fans, but bad if you don't). ERGO, make sure you have an air dam.
Old Oct 25, 2002 | 04:46 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
:hail:
Old Oct 25, 2002 | 05:59 PM
uk89camaro's Avatar
Sticky for :
1. Air dam
2. Manual fan switch
3. 160* temp switches
Would this kill all posts?
Old Nov 7, 2002 | 09:15 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
so the entire ram air design on the tech articals section... wouldnt that defeat the purpose of the air dam? if so, then i need to re adjust mine... cau sei hooked the vets from behin dmy fog lights to my dual filter box thing.
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
tommy z-28
Oct 6, 2015 10:58 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
