Leaking coolant, but
Old Dec 13, 2002 | 02:41 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
it only happens when it is cold outside. Very, very, very rarely it will do it when warm out, maybe once all year, til winter. Then it gets cold out, it leaks sometimes. A puddle maybe about a 6" radious. It's up front, pass side, almost right under the radiator. I've checked all the hoses and had the one from the radiator to the heater core replaced as well as the one from the hc to the radiator replaced at the same time. I know there is another hose on that side, a bigger one, haven't replaced it, but the leak doesn't seem to come from up that high. Any ideas or suggestions would be appreciated.
Old Dec 13, 2002 | 02:59 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
are you running the heat only when its cold outside?
Old Dec 13, 2002 | 03:25 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Yep. Only have the ol heater on when it's cold out.
Old Dec 19, 2002 | 03:42 PM
Andy Bush's Avatar
Could it be the radiator cap? They need changing occaisionally because of the two spring loaded valves in the cap leak and stick eventually. The leak could be the rubber seal getting old and hard in the cold.
Old Dec 20, 2002 | 04:32 AM
MdFormula350's Avatar
yeah the rad. cap could be the problem.
Old Dec 20, 2002 | 03:54 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Sweet thanks guys! I'll check it out.
Old Dec 21, 2002 | 04:25 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
ok i have to say this just so you dont get stranded like me.. if you havent done so yet replace your Heater Diverter valve (heater control valve) it may have a small leak in it and it could be signs tha tsomething bad is soon toi happen. second, i just had to replace my radiator because of a hairline couldnt pinpoint. if yours is the same its an easy replacement it took me 20 minutes. either way check both!
Old Dec 23, 2002 | 12:46 PM
philoldsmobile's Avatar
Car: 2009 Volvo V50 R Design
Engine: 2.0 turbo diesel
Transmission: 6 speed auto
Axle/Gears: yes, both
Wouldnt that be further back? the heater takes warm water right from the water pump doesnt it?
Where is this valve?
Old Dec 23, 2002 | 04:30 PM
FLYNLOW92rs's Avatar
It's around the passenger side valve cover......
Jack up the car, let it run with the heater on and see where it's comming from............i'm thinking it's the cap also though.......
Old Dec 23, 2002 | 06:31 PM
HamSpiced's Avatar
i agree i think its the cap but replace the Heater Divereter vbalve just in case, if you havent already, it looks like a mushroom with three hoses going to it. its near the front of the engine on the passenger side.
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
ULTM8Z
Oct 2, 2015 01:25 PM
