Any Tip's?
Old Dec 27, 2002 | 12:18 AM
305iroc's Avatar
Car: 91 Z28
Transmission: 5 speed
Axle/Gears: 3.42's
Any Tip's?
Going to install new head gaskets. Already pulled heads off today. Anything I should know before I put the thing back together.
Old Dec 27, 2002 | 02:37 AM
breathment's Avatar
you should try the General Tech forum too...
Old Dec 27, 2002 | 09:33 AM
89rsIMPRTETR's Avatar
well first of all you might want to use new head bolts depending on age and milage of the car, secondly make sure to tighten them down with the right amoount of torque, and last make sure that after you are done, lightly break in the new head gasket, what i mean by that is drive it fairly slow for the first couple hundred miles so the new gasket settles in
hope that helps
Old Dec 27, 2002 | 10:02 AM
MdFormula350's Avatar
what gaskets did you get?
Old Dec 27, 2002 | 09:56 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
dont forget to retorque them bolts after u let it warm up for the first time.cant ever be to safe u know
Old Dec 31, 2002 | 12:47 AM
305iroc's Avatar
Car: 91 Z28
Axle/Gears: 3.42's
I'm using Fel-pro gaskets.Well I've got the heads on. Everything's going good. Almost finished just need alittle more time. Thanks for the tips.
Old Jan 6, 2003 | 12:02 AM
305iroc's Avatar
Car: 91 Z28
Axle/Gears: 3.42's
We everything went well. Put a few hundred miles on the car and no problems.
Old Jan 6, 2003 | 01:45 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
glad to hear. did u do any performance mods or just needed to replace some gaskets?
Old Jan 6, 2003 | 07:52 AM
glad to here it man, its nice when everything goes your way isnt it
Old Jan 6, 2003 | 10:32 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
head gasket
dont know if you already have the heads on but make sure you scraped all the old gasket material off really well and maybe even lightly sand paper it like 300 grit and clean out the cylinders while your in there. also since you took the distributer out make sure you get the exact timing! if you need help on timing let me know i've done it all
good luck
Old Jan 8, 2003 | 12:50 AM
305iroc's Avatar
Car: 91 Z28
Axle/Gears: 3.42's
Well I just want this motor to last alittle longer. I'm building a different motor for it(350). Just bought the heads this week. Edelbrock aluminum performers. Still have alot left I need. My motors tbi but I'm get tpi from a friend. I'm going for 300 rear wheel hp at about 5500rpm but I'll see what happens. At least I have accsess to a dyno. Ive been really looking in the tbi to tpi conversion. Seems pretty simple they even use the same ecm. Should have the motor finished in a few months.
jrdturbo
Mar 31, 2016 02:58 PM
Thaney9
Oct 15, 2015 06:37 AM
Night rider327
Sep 25, 2015 04:47 AM
