Strange overheating
Old Feb 8, 2003 | 12:13 PM
SgtSkip's Avatar
Strange overheating
I have been having overheating probs for a while. I stay at 160 when the outside temp is below 70 degrees. Above that, the sky's the limit. I have a grade I drive that's not too steep but it's about 10 miles long. In the cooler weather (below 70) I stay right at 160. anything above that and I overheat. at 80 degrees I reach the red zone on my gauge by the time I hit the top of the grade. In traffic in the above 70 degree weather I can hit 240 after about 20 min.
Why does a slight change in ambient temp make such a drastic (80 - 100 degree) diff in coolant temp??? I'm sure there's a thermodynamics explination!
Old Feb 8, 2003 | 12:48 PM
MdFormula350's Avatar
that is strange.
what kinda of coolant mixture are you running?
Old Feb 8, 2003 | 01:49 PM
SgtSkip's Avatar
I'm honestly not sure! I am sure that it's no where close to 50:50. Probably mostly water. We used to run straight water in our big John Deere's in the summer (Florida, 100 deg +) to keep them cooler so I didn't even think about the mixture on my TA.
Old Feb 9, 2003 | 07:19 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Do you have an intact airdam?
Old Feb 9, 2003 | 10:16 AM
SgtSkip's Avatar
I have the center section only. Someone (I can't remember who) told me that the two outer sections wern't important. Bum gouge??
Old Feb 10, 2003 | 09:49 PM
H0TR0Dn's Avatar
Car: 88 Formula 350
The air dam is important for going down the road at highway speeds. It funnels air in through the radiator. Have you checked to see if your fans are working? They are needed for the slower speeds. When its cold out you could run without the fans for the most part. But when its warm or hot then ,ofcourse, they are needed. However if you have been running hotter then 240 for any period of time you might have warped a head. Which will eventually blow a head gasket. It can be minimal at 1st and will get worse.
Old Feb 13, 2003 | 07:29 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Do you not mean 240?
Old Feb 13, 2003 | 11:21 PM
H0TR0Dn's Avatar
Car: 88 Formula 350
Thanks RMK
Old Feb 16, 2003 | 05:18 PM
TwinTurboROC's Avatar
could be a screwy gauge or sending unit...
did u have a boilover yet?
do the fans/fan come on at a specific temp all the time... no matter what the temp is could be 260 or 210... if somone has another gauge try and use thiers to see if the temp gauge is faulty... if u can scan the temp sending units with a digital multi meter check for specific ohm ratings?
Bubbajones_ya
Jul 6, 2024 08:32 PM
Fanatic1074
Oct 3, 2022 05:57 AM
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
BWilcox
Sep 20, 2015 12:19 PM
