Not turning on
Old Mar 10, 2003 | 08:42 PM
RichSoucie's Avatar
Not turning on
I have a 1986 IROC-Z and the radiator fan wont turn on so i put a switch in to turn it on manually and that works but i want it to work the way it was ment to automatically i changed the sensor and it still dont work
Old Mar 10, 2003 | 08:46 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Does your setup have the dual fans or a single? If dual, does one fan come on? How about turning on the ac, does that stimulate a fan? Let us know. Also if you have dual fans and the secondary is not coming on, it is set to come on at a pretty high temp. over 225*.
Old Mar 10, 2003 | 08:52 PM
RichSoucie's Avatar
it has a single and i put a switch in to bypass it after it broke and this seems to turn it on just fine but what to do if i forget to turn it off at night or on in the morning
Old Mar 10, 2003 | 09:03 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Try some searches to find more explanations. About the only advice I can give you is to look for voltages in critical areas and make sure the fan switch is operating correctly. Try not to forget about the manual switch or you will have a dead battery on your hands.
Old Mar 10, 2003 | 09:04 PM
MdFormula350's Avatar
so you changed the coolant temp sensor? or the gauage sender?
if everything works with the switch, you have the switch hooked to the the ground wire of the relay right?
then for some reason the coolant temp sensor isnt getting the temp so the computer can ground the relay and turn on the fan at the certain temp the computer is set to..
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
