Air Deflector, is this mine?
Old Apr 22, 2003 | 08:23 AM
POS Camaro's Avatar
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
Car: 1985 Sport Coupe
Overheats (230 - 260) on the highway, especially with the A/C on.
Thought it was the 'missing' air deflector.
Bought 2 from Chevy, and it looks like mine is installed already, just a real small version.
From these pictures, is mine installed already?
Old Apr 22, 2003 | 08:24 AM
POS Camaro's Avatar
More
Old Apr 22, 2003 | 08:37 AM
noc_81's Avatar
I'm not to sure on a camaro, but the airdam on firebirds is seperated from the front end. If you already bought a replacement, I'd just put it on anyways. You could also check a shop manual for your car for more info.
Old Apr 22, 2003 | 08:42 AM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Yep, the Air Dams on a bird are much larger because the bird can only breath from the bottom, where as a Camaro gets a little bit of air from the front grill.
Old Apr 22, 2003 | 08:49 AM
85TPI400's Avatar
I dont know if yours is there or not but you should be able to get a 85 up Iroc/Z28/RS style one that hangs a bit lower and mount it to your car without to much trouble, im sure it would help out.
Old Apr 22, 2003 | 09:15 AM
POS Camaro's Avatar
I already bought the Z28 air deflector. Actually bought 2 of them.
The shop manual doesn't really talk about the deflector, I'll have to search the book some more.
The installed one looks like it is an integral part of the nose. I am planning on spending some cash on body work, maybe my best bet is to get a Z28 nose for it (no badging though, I don't want a Z28 clone).
It has the belt driven clutch fan, can that go bad and mess up the cooling?
I'm trying not to let the wife know that I spent $50 and might not be able to use the parts.
Old Apr 22, 2003 | 11:23 AM
82camaro's Avatar
Car: 82 camaro SC
Use the one you bought. It will hang down much lower than that 'thing' you have. It bolts right below the radiator. The 'thing' you have doesn't look like it will do much. Sure the fan clutch affects cooling--but that's usually an around town overheating problem if the fan clutch doesn't kick in. However, if you are indeed running 220+(assuming the guage is correct), that fan should be roaring loud.
Old Apr 24, 2003 | 07:22 PM
POS Camaro's Avatar
The thing that is already installed goes all the way around and bolts up under the headlight 'tray'. I don't really want to cut and hack the piece up to make it work. There are tabs on the one that is installed, I don't know if that is where an air deflector of some sort is supposed to be.
When I installed the gage, it was accurate using a test signal. The sensor is new, therefore I believe the temperature is accurate.
I'm going to replace the thermostat and possibly replace the fan. I don't know how the clutch portion works to determine if it is working properly.
Old Apr 24, 2003 | 10:39 PM
82camaro's Avatar
Car: 82 camaro SC
If the clutch is much more than 5 or so years old, it could probably be replaced. When the temp gets at or around 220+, you should notice the fan getting much louder--that's how you can tell if it's working.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
mustangman65_79
Aug 11, 2015 03:17 PM
