constant bubbles in overflow
Old Apr 25, 2003 | 12:34 AM
JAKEDPLAYA's Avatar
Hey guys I replaced my water pump, filled radiator a couple of times time it was full, put the cap on, and filled the overflow tank to the "cold mark" a few times, until cold level was reached.
Well my question is, why do I constantly get little bubbles up into the overflow jar???? Did i not correctly get rid of any air pockets????
Old Apr 25, 2003 | 05:57 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
try to take off the radiator cap and start up your car (note: do this while you car is cold. Hot water to your face and body aint such a good thing) if theres bubbles and waht not forming and coming to the top when you look into the radiator then your possibly in trouble
Old Apr 25, 2003 | 11:28 AM
DakotaSLT's Avatar
Possibly a dumb question, but if there are bubbles, what does this mean. You said "in trouble", but in what way? Air in the system?
Old Apr 25, 2003 | 12:10 PM
JAKEDPLAYA's Avatar
Has anyone ever experianced this type of thing?? If there is air, how do I get out??????
Old Apr 25, 2003 | 12:51 PM
jeffs82z28's Avatar
If you have bubbles forming in the radiator with the cap off, it can mean anything from a headgasket to a cracked head or block.
Old Apr 25, 2003 | 01:34 PM
DakotaSLT's Avatar
, wow I hope that's not the case with yours Jaked, good luck.
Old May 4, 2003 | 02:09 AM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
really? well damn it looks like i have a cracked head also.....and i found this out after i replaced everything to do with cooling....but if it was any of these wouldnt their be water in the oil or oil in the water?
Old May 4, 2003 | 02:35 AM
llvll4l2c91350's Avatar
when i had bubbles in the tank it turned out to be a cracked head. ended up replacing both. and yes my water was mixing with the oil. i noticed a little bit of creamy light brown paste-like stuff on my oil filler cap. i knew i was in trouble.
Old May 4, 2003 | 10:09 AM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
hhmmm have bubbles in my coolant tank but no water in my oil....looks like i need to go get my heads tested
Old May 4, 2003 | 01:44 PM
JAKEDPLAYA's Avatar
i just started my car with the radiator cap open, refilled the overflow to cold mark, and no bubbles since.
Old May 4, 2003 | 01:56 PM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
well ill try this..thanks
Old May 4, 2003 | 02:00 PM
JAKEDPLAYA's Avatar
the reason i did this was because i just put a new water pump on, and i think there was some air in the system.
But this water pump went on a new motor so I knew there was no chance of cracked heard or anything.
Old May 4, 2003 | 08:32 PM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
well my engine was just rebuilt and i put new water pump,radiator,etc. but today i went and bought a block tester and checked it and evidently i have a cracked head,bad gasket,or a cracked head....so i just got done unbolting everything and i just found out i have to take off the power steering pump so i will finish wit 1 side defintly tommorow
Old May 5, 2003 | 01:59 AM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
If the head, block, or the head gasket was cracked wouldn't the car be blowing white smoke? And if there were a problem with any of them, wouldn't he be loosing coolant, not getting bubbles? I think the smoke would be the first thing to look at for a crack problem. (knock on wood) I have never had a problem with any of them so I wouldn't know for sure.
Old May 5, 2003 | 03:00 AM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
well i never noticed till today that i had white smoke coming out my tailpipes..i also have water coming out of both pipes....im just hoping its the gasket but wont find out till tommorow
Old May 6, 2003 | 03:39 AM
88Bravo's Avatar
It depends on how much water, and if it is just water. If you notice, depending on the weather, brand new cars will drip water out of the tail pipe. It is due to the fact that the exhaust is hot and the pipes are cold. All it is most of the time is condensation. But in your case it might be something more.
And when antifreeze burns the fumes are white, and have a sweet smell. You can also look at the plugs to find out. Coolant when it gets into the chamber will clean out any carbon that is there. If you talk to people that hotroded back in the 60-70's during the TRUE muscle cars, some of them put cut coolant down the carb to clean out the heads.
Old May 6, 2003 | 04:23 AM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
well i tore the heads off anyways and when i took out the plugs it was a bad sight.....it lo0oks like no one has ever chnged the plugs....i checked the gap and it was in the .080's....and reallly really black...but the heads go off in the next couple days to get checked
Old May 6, 2003 | 05:07 PM
Beast_Vert350's Avatar
I know at work, we have had about 4 Chevy 6.2 diesels, come in for overheating and every single one of them had bubbles coming into the overflow jug, and every single one of them had a blown head gasket, cracked head, and cranked block. What is happening is on the compression stroke the compression is making its way to a water jacket and that is what is causing the bubbles to form in your jug. But hopefully the heads arent cracked your block is fine, and your heads arent warped and its just a blown head gasket.
Old May 6, 2003 | 06:03 PM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
yeah im really hoping tis too..thanks for the info
Bohemian
Aug 15, 2017 05:11 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
BWilcox
Sep 20, 2015 12:19 PM
84redta
Sep 19, 2015 09:58 AM
