will my v6 rad. work with a 350 tpi
Old Apr 29, 2003 | 08:30 PM
jc33's Avatar
Car: 1992 Camaro RS
Transmission: T5- manual five speed
i was wondering if there is any way i could use my rad for a 3.1 L MPFI with a 350 tpi. just seeing if i can save money somewhere in this swap but i dont want to risk overheating a new engine. all comments appreciated.
Old Apr 30, 2003 | 03:28 AM
txhotRS's Avatar
you could go to autozone...or O'reilley, or advanced Auto... OR WHATEVER is near you... and ask for the part numbers (and compare them) of a radiator for a 3.1, and a 350 from the same car... MORE IMPORTANTLY,,, since they should be the same dimensions... check the number of cores.. (mine has 3... for a 305, and it's the same for a 350, and MOST importantly.. check that all the hoses, and fittings go to the same place on both... if the radiator has the same # of rows (cores)... and all the stuff goes to the same place... THEN YES, it will work...
Old May 1, 2003 | 07:29 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Hoses arent in the same place
Vintageracer
Jan 10, 2020 05:33 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
djmarch
Aug 11, 2015 10:22 AM
