new motor gettin TOO HOT
Old May 8, 2003 | 01:20 PM
fbody83's Avatar
Car: 1983 firebird S/E
Engine: Built 350
I did a motor swap and when i had my 305 in, it began to overheat and i got a new radiator and it fixed the problem. I put a 350 in and now that gets too hot. I have a 160 thermostat and the new radiator. It stays around 160 for about 20 mins then gets to 220, then keeps climbing if it climbs large hills on the highway. Could it be backpressure cause my y-pipe under my car now is pretty flattened out from hittin the ground. Or do i need a better radiator or something? Thanks.
Old May 10, 2003 | 04:42 PM
Z28chrismac's Avatar
How are your fans, put additional fans on your radiator. Could also be your gage or your temp. sender going bad. Mine gage went out and would constantly rise until I hit the sh!@ out of the dash- then it would go to normal.
It could also be your timing, or it could be your engine running lean. Both of those cause the engine to run warmer.
Old May 10, 2003 | 05:03 PM
fbody83's Avatar
Engine: Built 350
my sensor is new cause i needed a new one to fit the block. Im pretty sure the gauge works right cause if its cooler out like at night it doesnt get very hot. My fan is mechanical and my shroud is fully intact. I dont think im runnin lean cause i smoke a lot if i punch it on the highway which would mean im runnin rich if anything right?
Old May 14, 2003 | 02:37 PM
fbody83's Avatar
Engine: Built 350
anyone else? i wanna solve this problem before its starts to get 80 and 90 degrees out
Old May 14, 2003 | 03:33 PM
kdgreen's Avatar
Get a 185 degree thermostat, 200 degree hypertech fan switch, and dual fans from a iroc/tpi car. I tried the 160 degree thermostat and my car ran super hot. The thermostat opens too cool and lets the coolant flow through to fast and it doesn't set in the radiator long enough to cool. Also make sure your air-dam is in place. My 350 has yet to get over 200 with the a/c on. In 92 degree weather.
Kevin
Old May 15, 2003 | 07:18 PM
Dan88IrocZ's Avatar
Just try a manual fan switch.
I couldn't solve my electrical overheating problems, so I just wired them suckers to a switch, and she's yet to see over 200 degre's.
Old May 19, 2003 | 02:59 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Very high exhuast backpressure will cause an engine to run hotter than usual.
Old May 21, 2003 | 07:13 AM
ctandc's Avatar
All good points...but don't forget that NEW / REBUILT Engines WILL Run a bit hotter than normal while being broke in alot of times....there's a bit more internal friction going on while the new parts "get used" to each other, and this causes heat.
HTH
theshackle
Mar 5, 2017 06:37 PM
krisner89
Oct 10, 2015 06:03 AM
TheExaminer
Aug 26, 2015 04:59 PM
Tonyy_z
Aug 12, 2015 07:20 AM
Leggman1
Aug 6, 2015 04:15 AM
