Air Dam - Bolt/Nut question
Old May 9, 2003 | 04:15 PM
edin's Avatar
just curious, what size bolt/nut or whatever do i need to attach my air dam to my 1991 camaro rs? i just bought a new air dam at the dealer and they were unsure which type of bolt/nut/etc i would require to attach this thing. any help would be great. thank you. edingeek@yahoo.com.
Old May 10, 2003 | 08:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I believe the bolts are 10 mm. Doesn't the RS already have an air dam? If so, you should already have what you need.
JamesC
Old May 10, 2003 | 11:28 AM
edin's Avatar
it DID have one, but someone swiped it AND all the hardware associated to it. 10mm u think? i'll check it out. thanks.
Old May 10, 2003 | 03:30 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
My car did not have an airdam when I bought it. I just used some nuts, bolts, and lock washers I found in the shop that fit the holes on the car. Doesn't really matter as long as they fit...
Old May 10, 2003 | 05:38 PM
JamesC's Avatar
If nothing else, hit a bone yard. Actually, you could have picked up the dam and the hardware there for next to nothing.
JamesC
Old May 13, 2003 | 11:08 AM
edin's Avatar
i looked at a couple junk yards, all the camaros they had either had no air dam or some busted *** ones. i ended up going with 5mm bolts (the holes in my car were like 5mm, but the holes in the air dam were more like 10mm), and some washers to fit the air dams large hole to the car's smaller holes. thanks everyone.
Old May 18, 2003 | 11:33 AM
theredmarlin's Avatar
Air Dam bolts and bracket
I have exactly the same problem with one added twist. The person that fixed my car didn't replace my air dam, so I bought a new one. Only to find out that he had also removed the piece you attach the air dam to! Can anyone tell me where a good place might be to start looking for the air dam bracket (I'm not sure if that's what it's called)?
Thanks in advance. Denise
88 - Sport Coupe - M5 - LO3 V8 - 9.3:1 - 5.0 (305) - 170@4000 - 255@2400 - TBI - 3.08 - 2.73 - 1988 5-sp Warner Gear - LO3
Old May 18, 2003 | 04:17 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Umm, what?
The air dam should bolt underneath the radiator core support. That is a structural piece of the car. It is not removable...
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
wruiz
Aug 13, 2015 09:07 PM
