Another Nubie Sorry, Need fan swich connection help!
Car: 1991 Camaro Z-28 (Durango R/T)
Engine: 383 L98 W/ HSR
Transmission: 700R4 Tuned Shift 2600 Stall
Axle/Gears: 3.73 10Bolt Posi W/ Al Cover, Disks
I just bought one of the hypertech low temp fan switches. i installed it, mostly. I is supposed to be really hard to tighten in?
I got three Quarters of the way and i cant get it any firther with my rench i am off a little so i have to get my friends 21mm. I am afraid that i may have cross thredded it or is it supposed to be hard. i also know many people put some kind of lock tight on the threds i didnt because i didnt have any. I this bad will it fall out? Also will this make it harder to bolt in.
Also the cable that came with the switch has the connector for the sensor at one end and a female clip at the other end. My problem is that my old sensor clip shatered when i took it off and there is no visible connector of any kind male or female around to disconnect it at. I am not sure if it is inside the heat protection housing or where it is but i can not get it connected right now
Please help
Need any more info to help just ask me and i will post it.
Thanks,
Raptere
Eli J.
Please help
Thanks,
Raptere
Eli J.
It is about parralel with the spark plugs uder the header i had to get to it from undernith inside the whole in the a arm, tight fit. it is on the passanger side between the back two spark plugs.
gta892000
Sep 16, 2015 12:37 AM
