Radiator Fluid in car
I go out to my car this morning and there is a 2 inch deep puddle of radiator fluid on the passenger floorboard!!!!!!!! For the love of *** what happened to my car please help me????
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
sounds like the heater core....
its like a small radiator.. when the heat is on, coolent flows thru it to warm up the air...
but when they go out, they dump coolent on the passenger floor space...
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I've seen it before. Not a fun thing to change, but its not impossible.
9d1burd just went through this with his GMC Jimmy. He had the orange stuff and it stained his grey carpet.
Definately the heater core. I had one go out in my old Pontiac 6000 when I was in college delivering pizza. It sprayed coolant all over my feet and legs. That sucked. Definately don't drive it until you either fix it or bypass it. Find the coolant hoses going into the firewall, and get something like a U shaped brass pipe to route them into each other. Your heater won't work until you get it fixed. But if you bypass it, your car won't know the difference. Just be sure to add more coolant! It's summertime, so it shouldn't matter until you have time and money to fix it. Matt
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
Whatever you do, don't buy the "radiator leak fix" crap. If you know how to change oil, and install stereo speakers you'll have no problem changing your heater core. If you don't have one get a Hayne's or Chilton's Manual for your car, and follow the directions. It takes a bit of time if you've never done it before but I assure you with a little patience and 3 or 4 hours of free time you can get it done.
Yeah I remember when that happened to my car too. Just make sure you either shampoo the heck out of your carpets or replace it entirely otherwise it will stink. Also whatever you do don't go to a dealer to get it fixed, they'll kill your wallet with the labor cost.
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
