POOL of Anti-freeze HELP!!! ASAP
Old Aug 12, 2003 | 04:43 PM
mace87's Avatar
there is a pool of anti freeze on the floor, of the passenger side. I just replaced the heater core today, so unless it is a bad one. What the hec caused this leak. It also drips from under the car. and its not a little at a time either.... Anyone else ever had this problem? if so what the hec do I do????
Old Aug 12, 2003 | 07:25 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
something to do with that heater core
Old Aug 12, 2003 | 11:49 PM
Wesdog's Avatar
Car: 85 T/A
Engine: Rebuilding
Check the hoses that connect to the heater core. The clamps may not be tight enough.
Old Aug 13, 2003 | 10:25 AM
mace87's Avatar
i just replaced one of the hoses and put new hose clamps on them. Is there any other component in that general area that has anti freeze running through it? And why would there be a pool of anti freeze on the floor, if just the clamps were loose. but I will check that out. Thank you
Old Aug 13, 2003 | 08:53 PM
MdFormula350's Avatar
well its under pressure, so it still could leak alot with not being tightened down all the way. thats the only part i can think of in that area that holds coolant.
Old Aug 14, 2003 | 02:01 PM
bigals87z28's Avatar
Car: Check The Sig
yep, its your heater core... either tighten the clamps, or get ready for ripping it out.
Old Aug 15, 2003 | 05:45 PM
mace87's Avatar
I fixed it. The clamps were loose. Thank you guys for your help
Old Aug 20, 2003 | 12:48 AM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
How hard is the heater core to replace, b/c my vent smells like coolant when the a/c is on and the car runs hotter than it used to
i assume this is the heater core, but i ve only had one time when i found coolant on the pass. floorboard. could it just be loose hoses? i don't want to replace it if i don't have to
thanks for any help
Old Aug 20, 2003 | 09:11 PM
onebinky's Avatar
Could be in the engine compartment too, and it's pulling the smell in thru the ventilation intake on the cowl. That happened in my 85 Z28. The seam on the side tank of the radiator split and would leak under about 13 PSI, so whenever the car heated up it would steam and leak antifreeze. That was a fun one to troubleshoot, because whenever I would stop and look for the leak, it would have stopped and all the antifreeze on the radiator was already evaporated, leaving only a puddle on the core support
Good luck,
Matt
Old Aug 20, 2003 | 09:15 PM
onebinky's Avatar
I see your parting out a car too I need a console lid in very good condition for my 87 IROC. If you still have it send me an email to quiktrp@yahoo.com with price and condition.
Old Aug 28, 2003 | 12:49 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
I have the same problem with coolant pooling in the passenger side floor when I run the A/C. The engine will heat up to 240 or better and then the leak happens. I will bypass the heater core and see if it still happens. If it doesn't then I will replace the heater core. Winter is just around the corner.
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
92camaroJoe
Aug 13, 2015 06:07 AM
