replacement radiator with no heater core barb?
Old Sep 3, 2003 | 05:23 PM
u r sofa king we tah did's Avatar
i got a replacement radiator with for free (cant beat the price so i took it since mine had a hole) and it hooks up all fine except on the passenger side below the filler neck there is no heater core hose barb to hook up the heater core hose? any ideas of how to get around this? which side of the radiator could i splice this hose into to get coolant into my heater core (pressure or return side)
Old Sep 4, 2003 | 04:36 PM
eddie jr's Avatar
the heater core to the rad??? Are you getting confused with the transmission cooler lines that splice into a rad??? I personally have never seen a heater core hooked to a rad. They usually hook to the water pump and sometimes the block or intake manifold for the other line. If you hook up to the tranny cooler lines then there will be no circulation of coolant as the tranny cooler in the rad is separated from the rad itself.
Old Sep 6, 2003 | 09:50 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
all camaros, from about 85 ish, had !heater hose from the intake and one to the rad
you will need tp splice into the same side as the stock locatoin
Old Sep 6, 2003 | 11:04 PM
eddie jr's Avatar
wow, intereting, ya learn something new everyday That's odd that they would do that only on the camaros?? After doing rad work on a few mid to late 80'd Firebirds I have never come across that.
Old Sep 7, 2003 | 10:06 AM
1986redbird's Avatar
I don't know how correct that is, I have a 85 and 86 and just recently stripped a 91 and have never seen the heater core hose hooked to the radiator.
Old Sep 7, 2003 | 10:24 AM
Dave Y's Avatar
Engine: 4.3L V6
hmmmmmmm, were any V8's?
maybe it was just V8's
here's pics of my 89 IROC
Dave Y's Avatar
Engine: 4.3L V6
heres where the hose goes
Old Sep 7, 2003 | 10:27 AM
Dave Y's Avatar
Engine: 4.3L V6
opps, here
Attached Thumbnails replacement radiator with no heater core barb?-close-pipe.jpg
Dave Y's Avatar
Engine: 4.3L V6
another
Attached Thumbnails replacement radiator with no heater core barb?-wide-pipe.jpg
Old Sep 7, 2003 | 10:29 AM
Dave Y's Avatar
Engine: 4.3L V6
and, as you can see, no place for hose on water pump(have heard some aftermarket pumps have a port)
Old Sep 7, 2003 | 10:30 AM
Dave Y's Avatar
Engine: 4.3L V6
and one more of w/p
Old Sep 7, 2003 | 10:23 PM
eddie jr's Avatar
Dave,
I think ya might be right about it being only on V8's cuz now that I think of it all the ones I worked on for rad stuff were V6's.
Old Sep 10, 2003 | 06:20 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
I have an 85, and there is NO hose that goes from the rad to the heater core. I had to block off that hole.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Street Lethal
Aug 14, 2015 08:25 PM
