teflon tape or no and tb bypass?
Old Oct 23, 2003 | 04:27 PM
grndmasnightmar
Guest
Posts: n/a
im replacing my radiator soon and i was wondering if i should use teflon tape on the tranny cooler lines? also the hose size for a tb bypass is 5/8 right? and where can i get the hose for this the only hose they had at home depot was for a washing machine and looked like it would melt.
Old Oct 25, 2003 | 12:26 PM
breathment's Avatar
u shouldn't need to. they didn't have teflon on there to begin with. thats why they are flared.
Old Oct 25, 2003 | 08:36 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
He's right, those are flared fittings and not NPT which do require teflon or sealant. For the hose, go to the Auto Parts Store and get a pack of heater hose. It is made just for that and probably cost a lot less than washer machine hose. Also get the rubber caps for the two fittings on the TB.
-Ozzy
Old Oct 25, 2003 | 09:17 PM
grndmasnightmar
Guest
Posts: n/a
cool
thanks for the help
Old Oct 26, 2003 | 01:10 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Where or what kind of caps can be used on the TB
Old Oct 26, 2003 | 04:50 PM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
They look like this:
It makes it look better instead of just having the coolant fittings shown. They are rubber and fit without clamps (no pressure).
-Ozzy
Old Oct 28, 2003 | 04:43 PM
grndmasnightmar
Guest
Posts: n/a
cool
thank you guys very much for your input
$750 L98
Feb 1, 2025 02:25 PM
gta892000
Aug 11, 2019 11:16 AM
roysatikas
Sep 22, 2015 08:15 PM
Formula8r89
Sep 22, 2015 04:24 PM
gta892000
Sep 16, 2015 12:40 AM
