Cooling fans are not workin?????
Old Dec 14, 2003 | 05:29 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
ok, i am stupid got my camaro out because my other car was out gas, well its snowy and icey out so i ended up gettin stuck in the driveway, well ice/snow got up inside and my fans locked up, and i noticed it when my car started gettin around 220 that something was not right, well i stop car, and notice that the fans are not working, so i break away the ice and get them to where they can move, but the fans still wont work, did it burn a fuse?? also these fan motors are new just a couple months old, did they burn the motors up ?? i need help asap, also my fans run all time wit the ingition turned over, please help asap, thanks a lot
well just checked fuse box, no burnt fuses
Old Dec 14, 2003 | 05:52 PM
MdFormula350's Avatar
definitely check each fan by hooking 12 volts to them and verify that they work, after that get back to us, or check the relays also.
Old Dec 14, 2003 | 05:56 PM
Engine: 305 tpi
ok, bout ten minutes ago i hooked up my 12 volt battery to one of the fan motors, and the one i checked worked, so i assume they both work, the relay appears to be good, i jsut replaced that a couple months ago too when i put the fan motors on, i checked the wiring appears to be good, is there any kind of fuse?
Old Dec 14, 2003 | 10:26 PM
Engine: 305 tpi
anyone?
Old Dec 14, 2003 | 10:35 PM
breathment's Avatar
there is a fuseable link which runs inline to the relay. not sure where its at. check near the battery though.
Old Dec 15, 2003 | 04:05 PM
Engine: 305 tpi
ok, my car is really acting weird now, the fans will come on everyone once in awhile, btw i have my fans set up so they come on when i turn the key, could them bein locked up by ice cause a short somewhere? i mean yea they could, but where should i look next?
Old Dec 16, 2003 | 03:32 PM
Engine: 305 tpi
anyone? they quit comin on at all again!! urgh this is makin me mad lol
Old Dec 17, 2003 | 05:00 PM
Engine: 305 tpi
anyone at all, this is a really big problem, i hate my car runnin around 220-230, i know it almost has to be a short somewhere, i just have no clue where to start, i looked for burnt wires and found none, so im clueless, like i said, yesterday they worked, then today they arent workin at all,
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
