switching to electric water pump..
Old Mar 24, 2004 | 09:34 PM
anubiscougar's Avatar
Ok, imma be switching to an electric water pump soon, ordered radiator last night, ordering csi water pump in prolly two weeks..
now.. when i get it in.. i plan on putting it all in(after i get fans of course, dun wanna use stock ones).. um.. but, once i do that, imma need a belt system to drive the alternator, compressor, & power steering pump... now.. i can't find a belt system that will do those three things w/o attaching to water pump
.. so.. is there an electric power steering pump out there or something? or is there a belt system i can buy? i don't wanna buy an electric water pump & loose my AC.. ya know.. i kinda like it here in FL(even tho it only works half bummed).
Old Mar 25, 2004 | 11:17 AM
goofnrox's Avatar
Is this for a drag car? If not, an electric pump is not what you want. They are not neary as effective as a belt driven pump, and are no where near as reliable. Then there is the belt issue. Most everything I've seen with electric pumps don't run alternators, or power steering, let alone AC?! I doubt that an elec water pump would even keep up on a hot day with the AC on.
I don't think an electric pump is what you really want, and you will be making your own type of mounting system if you decide to go down that route. I think the miniscule horsepower gains will not be worth the hassles.
Old Mar 25, 2004 | 07:13 PM
FBody90Formula's Avatar
Car: 1990 WS6 firebird formula
Engine: 305 tbi(lo3)
you might have problems routing the belt..i know there is a direct replacment electric water pump that uses the stock routing.it bolts on everything like stock.it claims to free up like 14 horsepower...but the water pump is like 449.00...so its pretty expensive
Old Mar 25, 2004 | 09:57 PM
wel... i've decided, to just get a decent mechanical water pump.. screw spending 250 for an electric & then having problems running the belt system.. i want it to be as easy as possible with the belts.. and throwing in an electric pump seems to put a big monkey wrench into it.
thx guys.
now which.. long or short pump? rofl.
Old Mar 26, 2004 | 09:16 AM
MCas7's Avatar
Long pump.
Old Mar 27, 2004 | 06:58 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
march has a bracket kit for an electric water pump.
Old Mar 27, 2004 | 10:04 PM
ok, so we have long pump... now which do we have, reverse flow or regular... i've read some ppl have reverse, do we all?
305 tpi, 88.
Old Mar 29, 2004 | 11:25 AM
goofnrox's Avatar
Regular for v-belt setup
Reverse flow for serpantine
Or...
Regular = Same as crank rotation.
Reverse = Opposite of crank rotation.
Old Mar 29, 2004 | 07:46 PM
would it hurt the engine if i ran it the opposite way that it as stock would go?
Old Mar 29, 2004 | 08:44 PM
goofnrox's Avatar
No, as long as the pump is spinning the proper way. A reverse pump need to spin reverse, and vise-versa, regardless of what came stock. People switch from serpantine to v, or the other way all the time.
Old Apr 2, 2004 | 12:01 PM
breathment's Avatar
madmax has a very nice electric water pump setup. might wanna go hunt down his post about it..
Hotrodboba400
Dec 10, 2019 07:07 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Dialed_In
Aug 20, 2015 01:45 PM
